Old 04-06-2010, 02:44 PM   #1
2000 31' Excella
Maryville , Tennessee
What temp. should air be from AC ?
Just curious if there is an all around temp. for air coming out of AC into camper.
Mine is about 56 degrees.......at least at first start up this spring.
Robbie
Robbie R. is offline   Reply With Quote
Old 04-06-2010, 03:02 PM   #2
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
do you mean holding a thermometer right at the outgoing vent? The air would be moving right? So that would mean some what of a wind chill. Ours comes out at around fifty also. But on the thermostat - if I have set it at 70......oh nevermind.... Ha ha! I will investigate this further...
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 04-06-2010, 03:44 PM   #3
Chief Chili Cook
newroswell's Avatar
2010 30' Flying Cloud
Bakersfield , California
You won't really get a fixed temp out of the a/c. It should be able lower whatever the temp is by about 20 degrees. Maybe a little more, maybe less depending on the age of the unit and if your a/c is in the shade or direct sun.
newroswell is offline   Reply With Quote
Old 04-06-2010, 04:27 PM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
20 degrees is the accepted standard for the drop in temperature for an AC unit.
Now that said if you get 15 you are on a smaller unit you are doing good. It has nothing to do with what the thermostat is set at it is only the mechanical capacity of the unit which is limited by the amount of Super Heat the refrigeration gas can carry.
2004 Excursion 4x4
Old 04-06-2010, 05:16 PM   #5
2000 31' Excella
Thanks.
So if it is 86 degrees inside and my vent is blowing at 57 (I checked with a thermometer) then this is ok ?
Robbie
Old 04-06-2010, 05:24 PM   #6
Originally Posted by Robbie R. View Post
Thanks.
Robbie
There should be a difference of about 18 to 20 degress, measuring the air temperature as it immediately enters the AC and as it immediately exits the AC.
Old 04-06-2010, 05:34 PM   #7
Ottawa , ON
Toadly, dude.
Now, paint your roof white, and inside the TT will drop another 10+ degrees, or so I've read on here several times...
Old 04-06-2010, 06:31 PM   #8
2000 31' Excella
Thanks, yes white..........I'll start on that in the morning.
Andy and everyone, thanks. I was a little concerned because it was 86 degrees in my 31 ft. excella and it seemed to take a good while to cool just a little but then I checked the temperature coming out it was 57......guess that is good and had I let it run for several hours it would have cooled it down to a comfortable temp. inside but I chose not to waste power and AC until I go camping.
Robbie
Old 04-06-2010, 06:42 PM   #9
Ottawa , ON
Yeah, and tht's why they are doing it at the factory now... Seriously.
Bearing temp n2916s Axles 13 04-07-2009 09:15 AM
Temp/Air bags...few other questions.. swinginping Classic Motorhomes 4 02-15-2008 09:10 PM
Fridge Temp? panub 1997 - 2004 Bambi 2 03-25-2004 01:22 PM
Temp Gauge thenewkid64 Mechanics Corner - Engines, Transmission & More... 12 09-27-2003 07:43 AM
