Old 11-26-2009, 09:21 AM   #1
1974 31' Excella 500
Livingston , Texas
What size furnace?
Have a '74 31' Excella 500 that came without a furnace - will put a new one in. It came with a 30k BTU unit, but comparable size new AS come with a 34K BTU unit. Read that you can oversize the furnace resulting in fast and significant temperature swings. What are your thoughts? Thanks, Heinz
H.Huester is offline   Reply With Quote
Old 11-26-2009, 12:34 PM   #2
The equal to the original, which was very adequate, is NT30SP, a 30,000 BTU unit, best I can recall.
I will not be in my office near any specs until Monday.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 11-26-2009, 05:40 PM   #3
mimiandrews's Avatar
1966 22' Safari
Hilltop Lakes , Texas
Same question for our '66 model 22' Safari. What is the appropriate replacement for the NT20--that's what the manual says it came with.
Old 11-26-2009, 07:23 PM   #4
I can give you the suggested replacement, but not until Monday.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 11-27-2009, 07:36 AM   #5
1966 22' Safari
Thanks, Andy. Have a great rest of the holiday!
I'll check this thread on Monday or Tuesday.
Old 12-03-2009, 04:06 PM   #6
1966 22' Safari
Hi Andy,
Had a chance to look at those furnace specs yet?
Old 12-03-2009, 04:51 PM   #7
Hi Andy,
I have been a little under the weather, but I will be in the office tomorrow.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 12-03-2009, 08:23 PM   #8
bhayden's Avatar
1978 24' Argosy 24
Woodinville , Washington
You could but that's exactly the opposite of what you want. Don't go any bigger than what was originally spec'd. If you can't get that get the next smaller size. You want to maintain an even temperature and avoid short cycling the furnace. A two stage furnace in a trailer would be ideal. You'd rarely use the high setting. A 34K BTU furnace in a 31' trailer is already the equivalent of a 120k BTU furnace (good for a 3,000 sq ft house) in a 760 sq ft studio appartment.
bhayden is offline   Reply With Quote
Old 12-04-2009, 12:16 PM   #9
Hi Andy,
The original furnace in your trailer was either a 20 or 22,000 BTU model, best I remember.
The 24,ooo BTU models are gone.
The two choices are a 19,000 or 30,000 BTU models.
But, the difference in price is $18.00.
Therefore I would suggest installing the NT30SP model.
It's better to have a little more, than not enough heat.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 12-04-2009, 02:03 PM   #10
1966 22' Safari
Thanks!
Old 12-04-2009, 02:04 PM   #11
1966 22' Safari
Which one of those furnaces would fit the cabinet and ducting best? Original furnace was an NT20, if the manual is right.
Old 12-04-2009, 02:21 PM   #12
The dimensions for the 19,000 BTU Suburban is 9 1/2" wide, 22 1/2" deep and 9 3/8" high.
The dimensions for the 30,000 BTU Suburban is 12" wide, 23" deep and 12 1/2" high.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 12-05-2009, 01:23 AM   #13
bhayden's Avatar
1978 24' Argosy 24
The original furnace in your trailer was either a 20 or 22,000 BTU model, best I remember... I would suggest installing the NT30SP model. It's better to have a little more, than not enough heat.
Why on earth would you want 30,000 btu to heat ~200 sq ft of living space. That's 2-1/2 tons of heating capacity. Way more is not better than the right amount. Fast temperature swings are not what leads to comfort. You want air circulation and an even temperature. It's also a lot more efficient. A furnace that short cycles wastes a ton of energy because every time it turns on the heat exchanger has to warm up before the blower turns on and then wastes the energy cooling down after it shuts off. You also end up sending a lot more heat out the exhaust.
Heat calcs for a home are a bit more straight forward because you have a design temperature for where the home is located. Our "winter camping" has been limited to the North Cascades in October when night time lows were near freezing. Plugged into shore power a 1500 watt space heater was more than adaquate for out 24' Argosy. 1500 watts is about 5000 BTU output which would be equivalent to a 6000 BTU furnace (80% efficient).
Unless you're planning to do all of your camping north of the Artic Circle in the dead of winter with no shore power I can't imagine ever needing that much heat. And if you do your tow vehicle had better be a propane tanker
Old 12-05-2009, 04:56 AM   #14
Lothlorian's Avatar
Loganville , Georgia
I just put the recommended 30,000 BTU suburban furance in my 27' Overlander three weeks ago. It does not go on and off constantly. The airstream is so well insulated it keeps it from going on and off. When you first use the heater when it is cold outside it takes awhile to get all the cabinets and furniture warm. For about 30 minutes it will go on and off. Even then it is not bad. Once everything in the trailer is warm. It does not kick on and off that much. It is very quiet and efficient.
I think the engineers new what they were doing when they figured cubic airspace recommendations for that furnace. We really enjoy ours. Our house furnace cycles more then the airstreams.
Brian
Brian & Adrienne
Lothlorian is offline   Reply With Quote
Old 12-05-2009, 07:28 AM   #15
The replacement furnace's available, in this case, is very limited, unless the owner wants to do a ton of modifications.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 12-05-2009, 04:40 PM   #16
bhayden's Avatar
1978 24' Argosy 24
50% isn't a little more. Most trailer furnaces are already sized to bake your eyeballs out. Massive overkill makes it that much worse. We've got a 48k BTU (4 ton) heat pump that keeps an old 1961 vintage home with massive amounts of glass and cathedral ceilings warm down to 20 degrees before the auxiliary gas furnace kicks in.
Old 12-05-2009, 06:36 PM   #17
Images: 59
I installed a 20k btu Suburban furnace in my 24' Tradewind. It run about 10 minutes three times an hour when the outside temp is below freezing.
It keeps the trailer very warm and comfortable, although no furnace will keep the outside walls warm to the touch when it's 20 degrees outside.
Old 12-07-2009, 06:50 AM   #18
1977 Argosy 24
Milltown , Wisconsin
If the original furnace was 20 or 22,000 BTU's, I would go with the 19,000. The 30,000 is WAY too big, they are used to heat a 31' AS. The worst that would happen if it's below zero is the 19,000 BTU furnace would run a lot.
ventport is offline   Reply With Quote
Old 01-12-2010, 11:34 AM   #19
pickerdd's Avatar
1971 23' Safari
Marietta , Georgia
From reading through this thread I'm wondering if I made a mistake. I purchased a new NT34SP from Forrest River (that's the company name on the invoice) to replace the original furnace in our '71 Safari, which I'm guessing is a NT20 or NT22. Suggestions?
- David
1971 23' Airstream Safari - "Moe"
2017 Ford F350 4x4 6.7 CCLB - Silver/Black - "Max"
pickerdd is offline   Reply With Quote
Old 01-12-2010, 11:42 AM   #20
Wise Elder
Jammer's Avatar
2010 30' Classic
If you come to Minnesota you'll be glad you have it. Around the Atlanta area it's more than you need.
What size TT have the same size awnings LI Pets Awnings 11 07-19-2014 01:04 PM
Plug size and ball size for '66 Safari 22'? Jezibels Hitches, Couplers & Balls 3 08-13-2009 06:59 AM
What size mok Member Introductions 4 05-31-2008 05:50 PM
New Furnace BTU size for 31ft trailer Kstar Furnaces, Heaters, Fireplaces & Air Conditioning 7 02-06-2006 02:47 PM
Twin Size Size Over59 Upholstery, Blinds, Walls & Interior Finishes 5 08-20-2004 10:18 AM
