Old 12-05-2009, 07:28 AM   #15
Originally Posted by bhayden View Post
Why on earth would you want 30,000 btu to heat ~200 sq ft of living space. That's 2-1/2 tons of heating capacity.
It's better to have a little more, than not enough heat.
The replacement furnace's available, in this case, is very limited, unless the owner wants to do a ton of modifications.
Old 12-05-2009, 04:40 PM   #16
bhayden's Avatar
1978 24' Argosy 24
Woodinville , Washington
50% isn't a little more. Most trailer furnaces are already sized to bake your eyeballs out. Massive overkill makes it that much worse. We've got a 48k BTU (4 ton) heat pump that keeps an old 1961 vintage home with massive amounts of glass and cathedral ceilings warm down to 20 degrees before the auxiliary gas furnace kicks in.
bhayden is offline   Reply With Quote
Old 12-05-2009, 06:36 PM   #17
Images: 59
I installed a 20k btu Suburban furnace in my 24' Tradewind. It run about 10 minutes three times an hour when the outside temp is below freezing.
It keeps the trailer very warm and comfortable, although no furnace will keep the outside walls warm to the touch when it's 20 degrees outside.
Old 12-07-2009, 06:50 AM   #18
1977 Argosy 24
Milltown , Wisconsin
If the original furnace was 20 or 22,000 BTU's, I would go with the 19,000. The 30,000 is WAY too big, they are used to heat a 31' AS. The worst that would happen if it's below zero is the 19,000 BTU furnace would run a lot.
ventport is offline   Reply With Quote
Old 01-12-2010, 11:34 AM   #19
pickerdd's Avatar
1971 23' Safari
Marietta , Georgia
From reading through this thread I'm wondering if I made a mistake. I purchased a new NT34SP from Forrest River (that's the company name on the invoice) to replace the original furnace in our '71 Safari, which I'm guessing is a NT20 or NT22. Suggestions?
- David
1971 23' Airstream Safari - "Moe"
2017 Ford F350 4x4 6.7 CCLB - Silver/Black - "Max"
pickerdd is offline   Reply With Quote
Old 01-12-2010, 11:42 AM   #20
Wise Elder
Jammer's Avatar
2010 30' Classic
If you come to Minnesota you'll be glad you have it. Around the Atlanta area it's more than you need.
Old 01-12-2010, 11:58 AM   #21
You had a 20 or 22 thousand BTU furnace.
A very good upgrade would have been a 30,000 BTU furnace.
The 34,000 BTU is OK, but I think a little overkill, especially the additional cost.
Old 01-12-2010, 12:38 PM   #22
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
On my TW I replaced the NT22a with a NT30. No complaints. I was able to reconnect to the existing NT22a plenum and use the old duct work. It required a little bit of work to get it to fit but not too bad. There are past threads on the subject with excellent photos and instructions.
Old 01-12-2010, 12:54 PM   #23
fotochop's Avatar
1969 23' Safari
New Orleans , Louisiana
Images: 18
Same as Lumatic, I put an NT30 in place of a NT22 and have no complaints about cycling, heat level, etc...You can see it here:
http://www.airforums.com/forums/f427...t22-60035.html
A 19K btu would probably also be fine. I have this crazy dream of one day towing my rig out to Colorado and doing some SKIING! and hey, who knows....
There are many good threads on this, if you scroll to the bottom of the one above you can find a couple more links..
fotochop is offline   Reply With Quote
Old 01-12-2010, 01:22 PM   #24
pickerdd's Avatar
1971 23' Safari
Marietta , Georgia
Thanks for the reply Andy. The NT34SP cost $345 including delivery. The NT34SP was about $25 (give or take) more than the NT30SP.
- David
Old 01-12-2010, 03:23 PM   #25
Over59's Avatar
Putnam , Connecticut
Images: 37
You need a thermostat that you can adjust the anticipator. That keeps the temp more even.
Over59 is offline   Reply With Quote
Old 01-12-2010, 10:58 PM   #26
bhayden's Avatar
1978 24' Argosy 24
All that does is help to prevent overshoot. It does nothing to eliminate the short cycling that occurs with an oversized furnace. Your furnace heats up the heat exchanger to a certain temperature before it starts to blow air. Then it shuts off and the latent heat in the heat exchanger is mostly just lost. The more times per hour the furnace cycles the less efficient it is AND the less comfortable you are. You pay twice, more propane wasted and less even heat.
Old 01-13-2010, 06:35 AM   #27
Lumatic's Avatar
1993 34' Excella
Images: 16
When I changed out my NT22 to a NT 30 I had a problem with short cycling. I changed out to the cheapest Walmart thermostat I could find and it solved the problem. There was no anticipator in the OEM stat.
Old 01-15-2010, 01:19 AM   #28
bhayden's Avatar
1978 24' Argosy 24
The cheapest Walmart thermostat is better (for a while) than an old bi-metalic tstat that was malfunctioning; much like the cheapest Walmart tire is better than a 30 year old OEM tire that's leaking air. Better than not working is not a lofty goal. "Cheap" modern tstats are really pretty darn good. It's really not rocket science. Too cold, burn gas; too hot, stop burning gas. Doesn't affect the efficiency of the unit. 1500 watts is about 5k BTU. Most people will find a 1500 watt space heater sufficient in their trailer. I don't think anybody would seriously carry six 1500 watt space heaters around to heat their trailer. Really... that's how absurd it is! Place six electric space heaters around your trailer. Now, make it so that they all turn on full blast at the same time. If that's "comfort" then then you need a 30k BTU furnace.
What size TT have the same size awnings LI Pets Awnings 11 07-19-2014 01:04 PM
Plug size and ball size for '66 Safari 22'? Jezibels Hitches, Couplers & Balls 3 08-13-2009 06:59 AM
What size mok Member Introductions 4 05-31-2008 05:50 PM
New Furnace BTU size for 31ft trailer Kstar Furnaces, Heaters, Fireplaces & Air Conditioning 7 02-06-2006 02:47 PM
Twin Size Size Over59 Upholstery, Blinds, Walls & Interior Finishes 5 08-20-2004 10:18 AM
