Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 07-07-2003, 08:37 AM   #1
maznblu
Profile:  Ann Arbor
Question what refrigerant for '77 A/C?
Greetings.
We just returned from a three week trip through the steamy upper midwest (Wisconsin, Minnesota, Iowa). We had to rely on a couple of fans to cool ourselves down in the 90+ degree heat as the A/C didn't work. I suspect that it needs refrigerant. I don't have the manual here, so can't quote the make and other specs. My basic question, however, is what refrigerant to use? With regulations about CFCs, is there a way to convert an older A/C unit to modern refrigerant? Or am I looking at investing in a new A/C? Everthing else seems to work fine (switches, blower, etc.).
TIA for advice.
Eugenie
maznblu is offline   Reply With Quote
Old 07-07-2003, 09:18 AM   #2
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
If you have an original Armstrong AC unit there are service ports. This would allow you to have a competent AC repair guy recharge the unit. It should use R12.
Parts are available to repair it, but there is not a conversion kit that I am aware of.
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 07-07-2003, 10:21 AM   #3
Chas
Chas's Avatar
Profile:  Austin , Texas
Images: 22
First off I wouldn't suspect low refrigerant as being your problem. I would check to be sure the condenser fan is operating and verify that the compressor is running, then check the temp differentials and see how much it is cooling. I would say that the refrigerant circuit is very well sealed and not particularly prone to leakage.
Chas
Chas is offline   Reply With Quote
Old 07-07-2003, 06:57 PM   #4
smily
"Still Working"
smily's Avatar
Profile:  North Charleston , South Carolina
Armstrong AC
My 1979 Armstrong has R-22
I bought a 30 lb bottle for 79 dollars and was told that I probably could not buy a 1 lb can.
Ken Smillie
My 1994 36' Classic MH is for sale
See it in the classifieds
smily is offline   Reply With Quote
Old 07-07-2003, 07:23 PM   #5
Chas
Chas's Avatar
Images: 22
R-12?
Really, R-22?
I figured they all had R-12 in them.
Well, good news for all of us because last time I checked R-12 was running nearly a $1,000 a keg (30 lbs.)
What's that, like $30 some dollars a pound?
Chas
Old 07-07-2003, 07:51 PM   #6
thenewkid64
Just a member
Images: 21
Uhhhhh..........
I may have the numbers mixed up. I have been discussing Automotive AC this week on the Motorhome. That would explain why I have R-12 on the brain
Chas you have the price right, that is what the r-12 recharge is going to run, 30.00 / LB, 3 lbs min.
Well it's just money, I am fortunate to be young enough to make more, right?
Brett G
Old 07-07-2003, 08:23 PM   #7
MECHANIC
Profile:
Re: what refrigerant for '77 A/C?
Originally posted by EAP
Greetings.
TIA for advice.
Eugenie
MECHANIC is offline   Reply With Quote
Old 07-07-2003, 08:27 PM   #8
MECHANIC
Profile:
My service manual says armstrong unit requires R-22
Is A/C original? whistler Furnaces, Heaters, Fireplaces & Air Conditioning 2 01-19-2004 05:32 AM
34' Excella 1000 needs cooler A/C cjholloway Furnaces, Heaters, Fireplaces & Air Conditioning 4 11-17-2003 07:50 PM
understanding A/C options Lexxy Furnaces, Heaters, Fireplaces & Air Conditioning 24 08-02-2003 06:29 PM
A/C blowing the breaker Chuck Furnaces, Heaters, Fireplaces & Air Conditioning 13 07-08-2003 11:52 AM
Retrofitting Roof A/C 59toaster Furnaces, Heaters, Fireplaces & Air Conditioning 4 03-14-2003 05:54 PM
test
