Old 08-12-2014, 10:39 PM   #1
GaŽl's Avatar
1960 26' Overlander
In the North , FRANCE
Images: 8
What is this ? A heater ?
Hello,
It seems a heater but can you confirm me please ? And how did it work ?
I have this system but in a fair condition
Thank you !
Of course, you can move this thread if I put it in a bad place
1960 Overlander
2002 Chevrolet Tahoe
GaŽl is offline   Reply With Quote
Old 08-12-2014, 10:57 PM   #2
2005 19' Safari
GLENDALE , AZ
That appears to be a propane space heater. If you can locate a serial number nameplate on the device and provide the model number, part number etc., we can research online and provide links to operating instructions and perhaps an owners manual.
Old 08-13-2014, 12:05 AM   #3
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Is that a burner on the bottom with a glass cover?
If I am seeing that right I say it is a propane space heater with an intentionally long flue to transfer as much "waste" heat from the flue as possible.
I am saying that the base is a commercially produced heater of some kind with a homemade "heat exchanger" to increase thermal efficiency. (In theory anyway).
Old 08-13-2014, 01:34 AM   #4
GaŽl's Avatar
1960 26' Overlander
Images: 8
oh ok, it's a propane heater system...
This picture comes from internet, it isn't mine because I have an uncomplete system... and I think I can't find any serial number on the parts...
It not seems be an original system and I don't want to install a gaz system for the heater, so, I don't keep the system for the rebuilt...
Thank you very much for your quickly answers !
Have a nive day
1960 Overlander
Old 10-05-2014, 11:10 PM   #5
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
Victoria , British Columbia
It is an original heater, I saw it in a 54 flying cloud I tried to buy once.
thesignlady is offline   Reply With Quote
Old 10-14-2014, 03:00 PM   #6
2000 30' Excella
Monticello , Florida
It appears to be located next to the refrigerator...hmmm...
07007 is offline   Reply With Quote
Old 10-14-2014, 03:07 PM   #7
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
If it is a propane heater, I wouldn't want it inside the trailer. As old as it may be, it may leak propane. Propane is heavier than air and settles to the floor until you use a match. That will get rid of the propane and the trailer. Remove it and cap the line securely. Use yellow teflon tape when you cap it. In the US, yellow tape is for gas lines, white is for water lines. Then it sounds like you will have to install a new furnace. The furnaces are designed to isolate the gas and fire box from inside of the trailer so you don't get propane fumes in the trailer.
Gene
Gene
Old 10-21-2014, 10:38 PM   #8
GaŽl's Avatar
1960 26' Overlander
Images: 8
I agree, I think it's a too old heater system, it will be too dangerous to use it.
Safer to fix a new modern system (electric or propane)...
1960 Overlander
Water heater/ heater matrix repair montreal Classic Motorhomes 2 06-08-2012 06:00 AM
Propane Heater or Instant water heater valontjej Plumbing - Systems & Fixtures 1 04-09-2012 08:56 PM
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 07:17 AM
Water heater prob, pilot won't stay lit & heater won't fire. johnboy Water Heaters, Filters & Pumps 1 06-20-2006 04:24 PM
water heater and heater cabbage76 Furnaces, Heaters, Fireplaces & Air Conditioning 7 11-12-2003 08:06 PM
