Old 12-29-2014, 06:55 AM   #1
Airhead in An Airstream
SCopp's Avatar
1955 26' Cruiser Overlander
Longview , Texas
Images: 58
What is the quietest 15k BTU AC?
Hi all,
Hubby and I are redoing a 1955 Cruiser and want opinions on which 15k BTU rooftop air conditioner is the quietest? The one we have on our 73' is very loud and makes me crazy(ier)
Thanks in advance for the advice.
SCopp
SCopp is offline   Reply With Quote
Old 12-29-2014, 08:22 AM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Originally Posted by SCopp View Post
Hi all,
SCopp
There's probably a good reason that most ads for rooftop air conditioners (of any size) do not brag about their low decibel levels. But you can attribute most of the unwanted noise to two sources, the blower and the compressor motor. A fully-enclosed blower will be quieter than an open blower, so that's a feature to look for. Most compressor motors do not have any kind of sound shielding, but some Dometic marine HVAC units have optional neoprene wraps that can be put around a compressor motor to quiet it down. I don't know if they have these wraps for RV air conditioners, but it's worth looking into.
A typical RV air conditioner produces about 65dB inside the RV. For reference, normal human speech is about 60dB, so if you stand at arm's reach from someone with the air conditioner between you and they have to raise their voice to make themselves understood, your AC is putting out more than 60dB. Or else you're going deaf. But if you were going deaf, then a loud AC wouldn't bother you so much.
A good dB value to shoot for is about 55dB— or less, though I doubt you'll find any AC units in that size that produce less dB than that.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 12-29-2014, 08:40 AM   #3
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Atwood has released a line of rooftop ACs. Not low profile but they are supposed to be more quiet than competitors.
http://www.atwoodmobile.com/images/a...s-brochure.pdf
My brother in law is having one installed on his Class C MH non ducted air while he's getting his roof resurfaced. When he gets it back I'll have to check it out and see how quiet it is. His unit comes with a remote.
Kelvin
15K BTU Brisk Air vs. 15K BTU Penguin adwriter73 Furnaces, Heaters, Fireplaces & Air Conditioning 9 05-23-2011 10:32 AM
What genset for a 15K btu air conditioner kdenault Generators & Solar Power 12 08-23-2007 05:24 AM
Got my Carrier 15K BTU installed chuman70 Furnaces, Heaters, Fireplaces & Air Conditioning 2 06-22-2007 06:07 AM
15K BTU Dometic A/C tripping breaker silverback Furnaces, Heaters, Fireplaces & Air Conditioning 48 07-11-2006 09:14 AM
15k BTU A/C unit info Silvertwinkie Furnaces, Heaters, Fireplaces & Air Conditioning 0 09-21-2003 02:17 PM
