Old 06-06-2010, 07:08 PM   #1
Middleport , Ohio
What is a "fantastic fan" ??
Is it just a fan or a type of air conditioner.
Brucep is offline   Reply With Quote
Old 06-06-2010, 07:11 PM   #2
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
They are high-end vents. Check out their website: FanTastic Vent - Home Page
Vaughan
Old 06-06-2010, 07:11 PM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
It is a roof vent with fan. There are several options you can get with these. They are not an air conditioner.
http://www.campingworld.com/shopping...-fan-vent/1523
Richard
Old 06-06-2010, 07:14 PM   #4
lewster's Avatar
Naples, FL , Hood River, OR
It's actually a 'Fantastic Vent' but it is commonly known as a fan, which it indeed is!
They come in lots of flavors from strictly manual to fully automatic with rain sensors and auto opening and closing lids, and are priced according to options.
Another way to go is the Maxx Fan. This is similar to a Fantastic Vent, but comes with an integrated cover that when in the open position, still covers the opening to allow full operation in the rain. The Fantastic Vent will not do this unless an aftermarket cover is added, much to the factory's displeasure.
You can check out the respective web site to see the models available. They are great appliances for ventilating your trailer when no 120VAC is available (both work on 12VDC) and keeping it muck cooler than if you didn't have them.
Old 06-06-2010, 07:15 PM   #5
Rollerboy's Avatar
1963 30' Sovereign
Gaylord , Michigan
Send a message via Yahoo to Rollerboy
do any of them run on 110v ?
Rollerboy is offline   Reply With Quote
Old 06-06-2010, 07:16 PM   #6
lewster's Avatar
No. The beauty of these fans is that the do not require 120VAC so they are perfect for use when boondocking or dry camping where you will not e able to run the A/C due to lack of 120VDC power.
Old 06-06-2010, 07:32 PM   #7
AirsDream's Avatar
1999 23' Safari
Perrysburg , Ann Arbor
They also make / sell an item they call the "Endless Breeze" - which is a fan that looks like a small box fan and which operates on 12 volt also ... draws 1-3 amps, as I recall, and does a nice job of moving air around inside the RV or other vehicle. But most people think of the roof vent fan when one says "Fantastic Fan."
AirsDream is offline   Reply With Quote
Old 06-06-2010, 07:40 PM   #8
1983 34' Excella
1967 24' Tradewind
Images: 32
Just to be on the safe side, I have one of each. Replaced the original bedroom vent with a opaque flat lid Fantastic Vent from Vintage Trailer Supply (the 6000RBTA model with thermostat and rain sensor) and an Endless Breeze that I bought at the North Little Rock Camping World.
I can recommend both.
And, technically, not only does the Endless Breeze look like a box fan, it is one. A 12 volt one.
Vaughan
fan near fuse box "on" turns on sporadically? Aaron Zornes Batteries, Univolts, Converters & Inverters 10 11-16-2017 02:40 PM
1972 31' w/Propane Furnace "no heat all fan" FarHarley Furnaces, Heaters, Fireplaces & Air Conditioning 4 11-25-2004 08:34 AM
