Old 08-11-2006, 09:49 AM   #1
1966 17' Caravel
Seattle , Washington
Send a message via AIM to kitchenclose
What heater should I use? Wave8?
Greetings Airstreamers!
(This maybe a bit long to read but I'm trying to get in as much detail as possible)
I have a situation where I bot a Wave 8 heater for a 1966 17' Caravel. We're custom building the interior and ran into a problem where the heater is too big for the space. My mechanic is concerned I'll get too cold and this will dampen my camping experience. I have also heard that the Wave 8 would be perfect for the size of my trailer.
Anybody have suggestions or experience with the Wave heaters?
How close can you be to it when it's on? The only other place I can place it is in the galley next to the hot water heater. Even there the heater will jut out a bit.
Should I go with a Wave 3 and a Buddy Heater (combo deal)? The Wave 3 can fix below the bed and I can pull out the Buddy Heater if needed.
I'm trying to make good decisions and complete this renovation project before the Beverly Beach, OR rally in October.
Thanks fellow AS! I look forward to your suggestions.
Karen
kitchenclose is offline   Reply With Quote
Old 08-11-2006, 03:49 PM   #2
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
I had the Wave 6 on the wall adjoining the oven/stove upon entrance to my '77 Excella 500. The fold down couch was on the curb side to the right of the door. On low I could sleep with my head on that side of the couch and it kept it toasty warm. That would place it approximately 4' away. On high it would have roasted me.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 08-11-2006, 08:39 PM   #3
Tarheel's Avatar
2001 34' Limited S/O
Moyock , North Carolina
Images: 21
I'm using a wave 6 in my 34' but its not the sole source of heat. With the 8 you can always turn it down. I think the 8 will work well for you.
Keep the shiny side up.
WBCCI # 348
Past Region 3 President
Past President Tidewater Unit 111
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
Old 08-14-2006, 10:43 AM   #4
1966 17' Caravel
Thanks for the replies. Looks like I have to find room for the Wave 8.
Old 08-17-2006, 10:51 AM   #5
1966 17' Caravel
I decided to
1) keep the Wave 8 because I hate being cold
2) not to mount the Wave 8 because it takes up too much room in a very small trailer
3) use stands and a flexible propane hose so that I can move it anywhere in the trailer
wish me luck. I'll start posting pictures once my project is closer to completion. Which I hope will be in September.
K
Hot water Heater DClark Water Heaters, Filters & Pumps 15 08-25-2017 02:35 AM
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 05:16 PM
Repair or Replace Original Bowen Water Heater? Andy R Water Heaters, Filters & Pumps 8 11-16-2005 03:51 PM
wiring - water heater Craig Electrical - Systems, Generators, Batteries & Solar 12 10-02-2002 05:03 AM
Water Heater shell frame BobbyW Water Heaters, Filters & Pumps 0 04-29-2002 10:21 AM
