Old 06-17-2010, 06:11 AM   #1
1978 28' Ambassador
Savannah , Georgia
What color to repaint AC shroud?
Have been patching old AC shroud. Almost finished. Trying to decide what color to paint it. Choices seem to be grey, aluminum, or metallic silver. Any suggestions? Thanks. Jack
Skamper1 is offline   Reply With Quote
Old 06-17-2010, 06:42 AM   #2
1986 25' Sovereign
Plant City , Florida
This is a project that i have been wanting to do for some time. I would think Alu would be a good fit. However Rustolium makes a color called stainless steel that is a perfect match.
ck21084 is offline   Reply With Quote
Old 06-17-2010, 07:01 AM   #3
SilverHoot's Avatar
1967 24' Tradewind
Greenville , South Carolina
Have heard some say they should be white to since they will be hotter any other color. I'd like some shade of silver that best matches the trailer skin.
SilverHoot is offline   Reply With Quote
Old 06-17-2010, 07:08 AM   #4
lewster's Avatar
Naples, FL , Hood River, OR
Most of the large motor homes that I work on have painted shrouds. Some leave the top of the shroud white, but not all.
I had the shroud of the Dometic on my 19CCD painted Mercedes Silver by the body shop next door. It was almost a perfect match for the silver bullet.
Old 07-03-2010, 09:56 PM   #5
1972 27' Overlander
Saline , Michigan
I am finishing repairs to my abs original armstrong ac shroud on my 1972 international, mine is currently painted silver half way up the white on top, does any one know the original paint color, was it white and silver? What is the best paint to use on this abs plastic?
loechli is offline   Reply With Quote
Old 07-03-2010, 10:02 PM   #6
1969 31' Sovereign
Pensacola , Florida
Fire engine red
1969Lloyd is offline   Reply With Quote
Old 07-04-2010, 05:53 AM   #7
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
They are white. Any quarts of 'high hiding white oil base paint' Thats my story and I'm stickin to it.
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 07-04-2010, 06:45 AM   #8
airdreamers's Avatar
2008 28' International
Venice , Florida
Images: 14
I replaced the A/C cover at Camping World for less then $150. Why paint?
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 07-04-2010, 07:25 AM   #9
Journalist's Avatar
1969 25' Tradewind
Irmo , South Carolina
Because not all Airstreams came with a generic A/C cover. Some were trimmed to match the trailer and painted from the factory.
AIR #8891
Unrestored 1969 25' Tradewind
Overkill Tow Vehicle of the Year Award:
2001 GMC 3500 4x4 Dually 6.6L Duramax
Journalist is offline   Reply With Quote
Old 07-04-2010, 08:20 AM   #10
1972 27' Overlander
Saline , Michigan
After looking thru the photos section it seems that silver on bottom with white 1/2 way up as mine is might be original paint scheme.
Anyone know for sure on the 1972 with the armstrong ac?
would all silver make much of a difference in heat or sun reflection over white?
Steve
Old 07-04-2010, 11:03 AM   #11
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
I painted mine white on top and two shades of blue, see post #6 at http://www.airforums.com/forums/f427...ead-40795.html. Since then, though, the darker blue has faded to a dull turquoise color, lighter blue is just fine. Still better than white, but not what I had in mind. Used Krylon Fusion plastic paint.
Vaughan
Old 07-04-2010, 12:12 PM   #12
Journalist's Avatar
1969 25' Tradewind
Steve
White will reflect considerably more heat than any other color.
AIR #8891
1959 Globe Trotter - want to repaint Red numbers on front. Kim Cannon Clearcoat, Exterior Paint & Trim 3 01-25-2008 02:18 PM
repaint 405billc Clearcoat, Exterior Paint & Trim 4 04-09-2007 07:54 AM
Logo repair and repaint gparker Clearcoat, Exterior Paint & Trim 4 09-26-2006 09:20 AM
vinyl repaint ted368 Upholstery, Blinds, Walls & Interior Finishes 4 05-15-2006 09:53 AM
? repaint the Argosy 77 R GO C MH Clearcoat, Exterior Paint & Trim 7 03-20-2004 06:47 AM
