Old 06-07-2016, 07:55 PM   #1
1978 Argosy Minuet 6.7 Metre
1971 27' Overlander
1973 31' Sovereign
Griffin , Georgia
Images: 14
What btu size a/c???vand do heat strips in a/c work?
I am about to replace the air conditioners in my 22' and 27' airstreams. What size and make and model do you recommend ?
paddle whisp is offline   Reply With Quote
Old 06-07-2016, 09:05 PM   #2
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
Heat strips work, but they may not put out enough heat to keep the coach warm in really cold temps.
They put out 3415 BTUH per 1000 watts.
Old 06-07-2016, 09:12 PM   #3
TheGreatleys's Avatar
1974 27' Overlander
Baltimore , Maryland
Depends on how you plan to use the trailer and how well insulated it is. I put a mach 8 cub with a heat strip in my 27' and both the heat and AC are plenty for our purposes, besides being able to run on a Honda 2000 generator for boondocking. I couldn't tell you if that's the right choice for you, though. What are you looking to get out of the unit?
TheGreatleys is offline   Reply With Quote
Heat pump or heat strips? coolwhip40 Furnaces, Heaters, Fireplaces & Air Conditioning 17 05-03-2018 09:27 AM
13500 BTU vs. 15000 BTU Eddie25 Furnaces, Heaters, Fireplaces & Air Conditioning 14 12-20-2013 11:50 PM
HOT IN TEXAS!!!! Upgrade a 13,000 BTU to a 15,000 BTU? Does it help? bowhead13 Furnaces, Heaters, Fireplaces & Air Conditioning 47 07-19-2013 12:02 PM
15K BTU Brisk Air vs. 15K BTU Penguin adwriter73 Furnaces, Heaters, Fireplaces & Air Conditioning 9 05-23-2011 10:32 AM
Heat Strips? tcrum Furnaces, Heaters, Fireplaces & Air Conditioning 4 01-07-2010 08:37 AM
