Old 11-13-2015, 11:44 PM   #1
FlyingCloud3's Avatar
1950 21' Flying Cloud
1960 22' Safari
Newland , North Carolina
what are the options for having a silver-colored A/C?
I've got a 1950 Flying Cloud. I hate to spoil the clean lines but I need to add an A/C unit. I'd prefer a low profile model. And I'd prefer it was silver-colored or shrouded in aluminum to match the trailer.
How can I add the A/C and minimize the visual impact?
Thanks!
Ryan Franks
1974 Sovereign Land Yacht 31'
1950 Flying Cloud 21'
1960 Safari 22'
Newland, NC
FlyingCloud3 is offline   Reply With Quote
Old 11-13-2015, 11:47 PM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
Rattle can paint the cover.
CRH is offline   Reply With Quote
Old 11-13-2015, 11:50 PM   #3
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
You could have the cover painted silver with car paint, or you could form a cover over the plastic cover made of aluminum.
If you have access to a metal brake you could easily make a rudimentary cover that would look "right" on your older trailer.
Brevi tempore!
Old 11-14-2015, 04:37 AM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Thanks!
You can get a split unit, and put the compressor and condenser outside, on the tongue, for example. The cooling part can be mounted in a cabinet, with the fan blowing the cool air out into the interior.
Old 11-14-2015, 04:54 AM   #5
65CV's Avatar
Western , Massachusetts
You can also consider mounting an A/C inside a cabinet so that you have nothing on the roof. I know of 3 of us who have done it this way. Unfortunately, we have all documented it in longer restoration threads. Start with posts 346, 347 and 366 in this thread -- it has links to Toastie's and Becky's installs. You'll find three different methods of exhausting hot air.
It's a lot of work, but we're all quite happy with the result.
65CV is offline   Reply With Quote
Old 11-14-2015, 08:07 AM   #6
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Painting the A/C shroud is a good idea no matter what color you want it even if you want it white. The plastic used in the shroud breaks down over time due to exposure to ultraviolet light and becomes brittle. Painting the shroud protects it from UV.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 11-14-2015, 08:22 AM   #7
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Question HMW Polyethylene plastic.....
FWIW.....I bought a shroud from ICON Direct and found out after the fact that it is not easily painted.
It's ok as long as white or black works for you....
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 11-14-2015, 09:02 AM   #8
Wet-sanding first does help. Using latex paint also helps because it's a "flexible" coating, unlike epoxies and acrylics.
WBCCI #1105
TAC LA-4
Old 11-14-2015, 09:06 AM   #9
bganso's Avatar
1994 30' Excella
Truckee , California
I'd consider something like this: LG Electronics 8,000 BTU Portable Air Conditioner and Dehumidifier Function with Remote Control (48 Pints/Day)-LP0814WNR - The Home Depot
you're not making a permanent hole in your roof and can be vented through a side window.
bganso is offline   Reply With Quote
Old 11-14-2015, 09:37 AM   #10
CRH
1995 25' Excella
xxxxx , xxxxxx
Kryon Fusion is for plastic and works very well for me.
As far a silver goes, I painted a plastic bucket with silver/chrome paint of some forgotten brand to make an Airstream trash can. It has taken a beating and held up great.
Old 11-14-2015, 10:19 AM   #11
kdickinson's Avatar
1969 23' Safari
Palmer Lake , Colorado
Just had to replace the A/C on our 69 Safari. It was significant work because of the format of the original A/C which required only a small round hole at the entry point to the trailer. That A/C never did work very well anyway (my parents bought the trailer new) plus it dripped condensate all the time. So - new A/C. the shroud is black and I like it. The mechanic offered to paint it and once I saw it I thought it looked great. When it fades we may paint it back to silver but that will be a long time from now. Leaking is fixed now and it has a small pump in the collection pan to pump condensate out. Definitely worth every penny
kdickinson is offline   Reply With Quote
Old 11-14-2015, 10:49 AM   #12
Question
I finally gave up on duplicating the blue I added to the stock shroud.....
....tried 800 WS, plus heating the surface with a heat gun to draw the resin to the surface. But even after a wipe down with prepsol and a tack rag the AS decal slid off after the first wet-down.
PFC
"Tahawus"
RLC
John Prine
Old 11-14-2015, 11:55 AM   #13
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
I used Kryon Fusion a few years back and it has held up well. To avoid issues with the existing lettering, I made a template which was an elongated oval to cover the decals and taped it in place. The remainder was prepped and painted metallic silver. The taped portion was removed and the whole given a clear coat final layer.
SeeMore is offline   Reply With Quote
Old 11-14-2015, 03:33 PM   #14
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
Ue a primer that is formulated for plastic, you can get them at Sherwin Williams, give it a couple coats, then get a can of satin sheen of aluminum paint, (either brush on or rattle can), and you'll be good to go....
Larry
Old age is coming at a really bad time!
1996 34' Excella 1000, interior totally redone, 2003 Dodge/Cummins HO, U.S. Gear exhaust brake, Diablo tuner, 115 gallon aux fuel, Bedslide, Airsafe/Reese Dual Cam, and a bunch of other stuff
Larry C is offline   Reply With Quote
Black colored water when flushing toilet Mikec1231 Plumbing - Systems & Fixtures 3 06-20-2013 06:09 PM
Tips for polishing gold colored hardware? JeweloJalopy Vintage Kin 9 02-13-2013 10:18 AM
Replacing colored striping tape and words Stumpjumper Exterior Restoration Forum 5 04-12-2012 06:34 PM
Bronze colored rivets tripod58 Upholstery, Blinds, Walls & Interior Finishes 4 09-12-2010 11:12 AM
colored numbers jpeterman Forum Admin, News and Member Account Info 2 10-16-2008 08:27 PM
