Old 05-13-2010, 01:34 PM   #1
jfowler218's Avatar
2007 31' Classic
Bend , Oregon
Water heater slow to rewarm water
I usually shower first in the morning and my wife follows an hour or so later. She complains there is only luke warm water available. We have tried using both gas and electric to heat the water. There is always hot water available from the sink when she showers.
How long should it take the heater to reheat water? Is it possible the shower faucet is at fault?
jfowler218 is offline   Reply With Quote
Old 05-13-2010, 02:12 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
If you have hot water at the sink for the second shower it is not a heater problem but rather the mixing valve limit on the shower is set too low to allow enough hot water to the shower head.
Newer shower valves have adjustments built in them to insure you can't scald yourself.
Remove the valve assembly and you should find a ring with teeth around the outside of the ring. Each tooth generally equals 3 degrees of temperature change.
2004 Excursion 4x4
Gray Water Tank Slow Drain extiger Waste Systems, Tanks & Totes 14 05-11-2010 09:17 AM
slow drip behind outside water heater door iHayley Water Heaters, Filters & Pumps 12 04-30-2009 06:10 PM
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 07:17 AM
hot water water on demand with a with a normal water heater Frank's Trailer Works Water Heaters, Filters & Pumps 3 09-25-2007 12:24 AM
Fresh water tank - slow drip drboyd Fresh Water Systems 5 07-24-2003 07:01 PM
