Old 05-08-2009, 06:32 AM   #1
beerrun'r's Avatar
2013 25' Flying Cloud
ARTHUR , Illinois
Water heater "huffing & puffing"
For lack of better words, recently my pilotless ignition water heater on this '06 Bambi is "huffing & puffing".
The flame is blue when running OK, but occasionally it will yellow and even burn back into the mixer. I have recently had the gas pressure checked and it's OK.
Anyone had this problem in the past? Any suggestions?
beerrun'r is offline   Reply With Quote
Old 05-08-2009, 06:52 AM   #2
SteveH's Avatar
Common Sense , Texas
Check the air intake into pipe going to the burner for debris, like spider webs, etc. You might also want to check the burner itself for carbon buildup.
Most times when the flame is not blue, there is not enough air into the mixture caused by something choking off the air intake.
Good luck.
Old 05-08-2009, 07:10 AM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
Good luck.
Took the words right out of my mouth.
5 meter Langford Nahanni
Old 05-08-2009, 09:43 AM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
Blockage in the air flow would be constant unless the spider is moving around.
I have seen is a loose orifice cause this, and it was on a newer unit.
Another area I would consider, since you rig is newer, is if you do not have many miles on it I would look at the possibility of oil getting to the burner. This could be from the gas valve manufacturing or the gas line.
2004 Excursion 4x4
Old 05-08-2009, 10:11 AM   #5
Silver Sneaker
2006 16' Safari
Denver , Colorado
Our new '06 Bambi did the same thing, only needed an air adjustment. Moved the piece of pipe with the long holes in it and it was quieter also. Watch out, it may be hot. We're doing this full time and are changing elevation now and then so need to make an adjustment occasionally. Good luck.
Elvie is offline   Reply With Quote
Atwood water heater "not sparking" Moonstruck Furnaces, Heaters, Fireplaces & Air Conditioning 0 07-15-2007 12:44 PM
Water heater recommendation for a "landed" Sovereign? davida Water Heaters, Filters & Pumps 3 07-22-2006 07:50 PM
"Water Heater" not lighting Sneakinup Water Heaters, Filters & Pumps 2 02-08-2004 01:49 PM
"Water Heater" & SS Flex hose? Sneakinup Water Heaters, Filters & Pumps 15 01-31-2004 09:22 PM
