Old 04-04-2009, 11:46 AM   #1
mickeymoose's Avatar
1974 25' Tradewind
Gillette , Wyoming
water heater??
Is there any such thing as on on demand water heater that will fit in a 74 tradewind?
Cassidy
Cassidy
"Listen, do you smell something?" - Dr. Ray Stantz
mickeymoose is offline   Reply With Quote
Old 04-04-2009, 12:43 PM   #2
1972 25' Tradewind
plano , Texas
yes its called an rv 1000
it really pricey though about a $1000 bucks new
roguebrun is offline   Reply With Quote
Old 04-04-2009, 12:53 PM   #3
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
Cassidy,
You can read all about them here...
PrecisionTemp.com: For Recreational Vehicles and Boats
If the water heater in our '87 ever gives up the ghost, I hope to replace it with on of the on demand units.
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 05-26-2009, 04:15 PM   #4
Rick56Safari's Avatar
1956 22' Safari
Lakewood, WA in the summer and Boulder City, NV in the winter , WA / NV
Send a message via AIM to Rick56Safari
Does it have to be a gas on demand heater???
Check out these web sites:
Stiebel Eltron tankless electric water heaters from the PlumbingWorld
Quality electric tankless water heaters from the PlumbingWorld
My 1956 Airstream just had its 1956 original water heater give up the ghost... who would have thought a 53 yr old water heater would stop working.... :-)
and I am considering the tankless heater from Bosch. The problem for me is that I still have the original fuses too and would need to replace the screw in fuses with circuit breakers to get 30 amp protection.
Good luck
Rick
Rick and Joanna
On the road, cause she's always telling me where to go.
Rick56Safari is offline   Reply With Quote
Old 05-26-2009, 05:20 PM   #5
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
Too many amps
Good luck
Rick
The only 110 v I saw pulls 29 amps,you only have a 30 amp on a regular trailer,with resistance figured in you would have to shower in the dark.Dave
easyride is offline   Reply With Quote
Old 05-26-2009, 07:23 PM   #6
VIKING's Avatar
Boulder Creek , California
The DHC 3-1 is a 120 volt that draws 25 amps and requires a 30 amp breaker. That is right at the limit of what you could use, and you would have to pay attention to the other electrical draws to keep from tripping the main breaker. I would rather have a regular small water heater for a couple of reasons. One is that it limits your use of both resources(gas or electric, and water) to the size of your water heater tank. This limits how much grey water I produce(and store) and how often I have to visit a dump station. The fact that I can't run the hot water indefinitely is sometimes the only thing keeping me from doing it(Aquarius) The second reason is that I see the same disclaimer on many on-demand water heaters that says that the temperature will vary, that there is a minimum flow rate at which the heater will activate, that you have a greater chance of scalding yourself, and so on. It just turns me off.
I am looking at getting a shower sprayer that just puts out a heavy mist of water and has an easy to use on-off switch. I have a friend who uses a similar thing for a outdoor portable shower and uses only 1 to 1-1/2 gallons of water per shower. You boondockers are doing the math right now, I'm sure.
I also noted that my 45 year old bowen water heater got ten gallons of water up to temperature in less then 1/2 hour. I would hope that a new one would be a little better then that even.
Rich
VIKING is offline   Reply With Quote
Water wood rot under toilet and water heater! Mrcrowley General Interior Topics 4 12-01-2008 02:34 AM
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 07:17 AM
Water heater & fresh water capacity ESCAPE POD Water Heaters, Filters & Pumps 5 11-14-2007 04:14 PM
hot water water on demand with a with a normal water heater Frank's Trailer Works Water Heaters, Filters & Pumps 3 09-25-2007 12:24 AM
Water heater prob, pilot won't stay lit & heater won't fire. johnboy Water Heaters, Filters & Pumps 1 06-20-2006 04:24 PM
