Old 05-10-2011, 09:22 PM   #1
j Z
1979 23' Safari
Great Falls , Montana
WarmWire electric heat?
I have a 1979 Safari that is in the planning stages for a major restoration and renovation. I want the trailer to be habitable in winter conditions in North Dakota / Montana. For primary heating, I was considering running a warmwire under the new flooring. Has anyone ever tried this?
Electric Floor Heating Systems :: Electric Radiant Floor Heat :: Heated Floors from WarmWire.com
My plan is to remove all the furniture and cabinetry and start from scratch. The wire would be installed in a small channel that I could cut into the subfloor. New marmoleum flooring will go on top. The wire could also be run underneath the water tanks to keep them from freezing.
JZ
j Z is offline   Reply With Quote
Old 05-10-2011, 09:40 PM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
Carefully consider available square footage and watts per square foot. The problem with in floor heat is usually that there isn't enough of it even in a stick house where the ratio of floor square footage to outside envelope is better.
Old 05-10-2011, 09:56 PM   #3
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
On top of the challenge Jammer mentions with the ratio of floor area to skin area exposed to the cold is the fact that our trailers have nothing near the R-factor of even a somewhat poorly-insulated house. Also there's the no-boondocking quality of relying on electric heat... if you're caught out in the cold without 120V hookups and not winterized it would be bad.
— David
Old 05-10-2011, 10:17 PM   #4
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
A friend of mine with a Class A loves the electric heated floor, but then it is under ceramic tile. Are you planning on click panels marmoleum or sheet?
Bill
Just my personal opinion
Old 05-11-2011, 09:31 AM   #5
j Z
1979 23' Safari
For the marmoleum, I am not sure. I think the snap-panels would be the easiest to install and wouild give the floor a little more stability.
Old 05-11-2011, 10:13 AM   #6
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
However, the snap panels are thicker and may serve to insulate the wire instead of transferring the heat.
Bill
Old 05-11-2011, 10:36 AM   #7
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Based on the published power consumption ratings, it looks like you will be using more than 2/3 of your available 30 amps just to power this floor warmer. If you add the power your fridge will consume, and your converter, you'll be maxed out just with those items. If you want to run your microwave or even a toaster, you'll have to turn the system off.
Also, the floor warmer does nothing to keep the holding tanks from freezing. I think this has "bad plan" written on it.
cheap heat rv comfort systems - electric conversion of furnace? hshovic Furnaces, Heaters, Fireplaces & Air Conditioning 13 07-17-2012 01:18 PM
Had the honor to step inside a 1962 Bambi this weekend and fell in LOVE with the heat J5MM LP Gas, Piping, Tanks & Regulators 9 03-14-2011 02:52 PM
Electric Horn wiring diagram on a 345 John H. Classic Motorhomes 7 02-01-2011 03:07 PM
New Electric Service - YAY!!! or Life is Better When Everything WORKS!!! bugnot1 Winter Living 6 01-23-2011 10:32 PM
Heat Pumps Brianv512 Furnaces, Heaters, Fireplaces & Air Conditioning 8 01-19-2011 05:15 PM
