Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 06-20-2016, 08:34 PM   #1
1969 27' Overlander
Palos Verdes , California
Wanted: Shroud / Cover for Rooftop A/c Unit
Hi --- I want to buy an aluminum or fiberglass shroud / cover for the Armstrong rooftop a/c unit on my 1969 Overlander. Will consider new, used, or custom made. Thanks
Eric111 is offline   Reply With Quote
Old 06-20-2016, 08:55 PM   #2
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
A/C Shroud
New ones available. Check out the website InlandRV.com. Hope this helps, Ed
1967 Safari Twin "Landshark" w/International trim package
2014 GMC Sierra 1500 Double Cab SLE
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 07-02-2016, 11:46 PM   #3
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
The freight from Inland to wherever seems to run pretty high. You'll be way better off if you can figure a way to pick them up in person, or ship via Greyhound bus.
Old 05-01-2017, 07:27 PM   #4
1976 24' Argosy 24
1999 30' Excella 1000
White Haven , Pennsylvania
Hi Eric. Did you ever find a shroud for your Armstrong?
Gkiesel is offline   Reply With Quote
Move my rooftop AC unit? aquinob Furnaces, Heaters, Fireplaces & Air Conditioning 3 06-16-2014 09:42 PM
Need '77 rooftop shroud for stove vent flyflinger Roof Vents, Skylights & Fans 4 10-29-2010 03:13 PM
How do I clean rooftop ac unit? Chasmorgan Furnaces, Heaters, Fireplaces & Air Conditioning 1 08-21-2009 11:24 AM
Removing rooftop AC unit: how? davida Furnaces, Heaters, Fireplaces & Air Conditioning 6 10-17-2008 08:35 AM
