Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 12-02-2007, 12:13 PM   #1
Jetstreamer
Jetstreamer's Avatar
Profile:  La Follette , Tennessee
Wanted Duo Therm 90125 for parts
Hello:
I just removed, disassembled, cleaned, inspected. One has a crack in the burner can which I plan to mig weld. The other was fine. Plans call for an annual inspection of these furnaces, as well as any furnace installed is a top priority before use.
I've found new gaskets for all but the igniter box. I've been told to look for mechanical packing which is the angel hair like flame retardant material used for the gaskets. I'm still looking for it locally from my heat/air car club buddy but haven't as of yet contacted him.
Does anyone have a 901 they have scrapped from your rig, but just had to hang on to? I'd be interested in buying one cheap for parts.
I think conventional wisdom is to replace these units because of the age and recalls. Until I find a unit that's a direct replacement requiring no cutting and patching of the exterior skin, I'll continue my inspections.
Kevin in TN
Jetstreamer is offline   Reply With Quote
Old 12-02-2007, 12:20 PM   #2
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
Kevin,
I applaud your resourcefulness in trying to resurrect your furnace, but if there is a crack in it I WOULD JUNK IT AND REPLACE IT WITH A NEW ONE!!!!!
In any furnace, there is a disinct possibility of CO leaks and susequent poisoning, and FWIW, it's not something I would trust after that type of repair. You sure don't want to wake up dead one morning (I know, you wouldn't wake up, but that's a philosophical matter)
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Duo-therm heater harold1946 General Motorhome Topics 4 11-12-2007 06:08 PM
duo-therm not working toolman5252 Furnaces, Heaters, Fireplaces & Air Conditioning 6 02-04-2006 12:24 AM
? re Duo Therm Furnace - 1968 GT Bryanhu Furnaces, Heaters, Fireplaces & Air Conditioning 4 11-21-2003 09:52 PM
Parts for Duo-Therm 900 series furnace? 1985air345 Furnaces, Heaters, Fireplaces & Air Conditioning 2 01-22-2003 03:45 PM
Duo-Therm A/C on my Avion. 68 Suburban Furnaces, Heaters, Fireplaces & Air Conditioning 3 10-20-2002 08:09 PM
test
