Old 04-21-2014, 03:29 PM   #1
HCR
HCR's Avatar
Livingston , Full time traveler
Very low humidity --no AC condensate?
Humidity at 14 %. AC cooling well, but no water dripping from tube near wheel well so pulled inside cover on AC and put little finger in the drip pan drain --only a little moisture and it appears after two hours of running that water is NOT being produced.
When humidity this low is it possible no condensate is being created? Or have I got some problem that is keeping water from collecting in drip pan?
Airstream of Consciousness
HCR is offline   Reply With Quote
Old 04-21-2014, 03:42 PM   #2
dznf0g's Avatar
Oswego , Illinois
Normal
-Rich-
Dual A/C still not enough in 90 degrees, sun, wind, humidity? Jammer Furnaces, Heaters, Fireplaces & Air Conditioning 30 06-17-2014 11:07 AM
Controlling humidity Catman6 Full-Timing 23 03-31-2010 02:55 PM
Florida Storage & Humidity monkeypants Our Community 10 09-17-2009 07:29 AM
Humidity JLD Dehumidifiers & Ozone Generators 6 01-28-2008 06:08 PM
Controlling Humidity chaimemet Dehumidifiers & Ozone Generators 2 06-17-2007 06:07 AM
