Old 09-12-2009, 10:26 AM   #1
Islander
kingfisher24's Avatar
2005 28' International CCD
Deer Harbor , ORCAS ISLAND WA
vent free propane heaters???
Has anyone installed /use heater such as the Olympian 8000....
I am trying to figure out where to install such a unit...just now beginning research on these units
kingfisher24 is offline   Reply With Quote
Old 09-12-2009, 11:04 AM   #2
FLYNCLD's Avatar
1962 22' Flying Cloud
Bend , Oregon
We installed an Olympian Wave 6 just inside the door on the wall that holds the fridge. That puts in directly across from our bed and does the trick pretty quick in the morning. Not to mention I barely have to get out of bed to light it!! It works well, although the instructions for lighting it seem to have very little to so with the actual method!
FLYNCLD
FLYNCLD is offline   Reply With Quote
Old 09-12-2009, 02:45 PM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
On my trailer(s) they were installed on the bulkhead just as you came in the door on the left. That happens to correspond to the side of the stove cabinet. Neither of my units still have them installed, for whatever reason. But I do plan to put one back in when the time comes.
Aaron
WBCCI #XXXX AIR #2495
Old 09-12-2009, 05:56 PM   #4
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
Thats where our Cat-Heater is installed. Inside the door on the left which is the Stove and Oven bulk-head. We have used ours a few times, it works very well. ONE word of Caution. While advertised as ventless,any appliance while burns anything gives off CO2 /Carbon Monoxide. So make sure you open a top vent or window for fresh air.
Roger
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 09-12-2009, 06:14 PM   #5
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
Roger
I second that. Anything that's burning fuel needs to be vented, so at least leave a top vent open.
Adding a CO2 detector would be a good idea as well.
Better safe than sorry!
Stephanie
Old 09-12-2009, 06:19 PM   #6
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Roger
CO detector a must, ventless heaters are safe while showing a blue flame.
Another problem ventless heaters create is moisture as part of the burning process, requires an open vent, especially in a tight skinned AS.
Old 09-28-2009, 02:25 PM   #7
1965 22' Safari
Woodstock , New York
My '65 Safari came with an Olympian catalytic heater installed on the left side of the door next to the range. I've been reading up on it and evidently it should be covered so dirt doesn't get into the pad. Also you're not supposed to touch the pad. I had a little trouble lighting it the first time but used a match and it lit...may have to buy an ignitor part for it. Will definitely install a CO2 alarm as I am a little afraid of this device.
Does anyone know where to purchase this piezoelectric part? I've done some searching and cannot find this particular part for sale but did find a portable piezoelectric lighter.
jtaggart is offline   Reply With Quote
Free-Free-Free -- Twin Bed Setup - 1955 Flying Cloud Tx Air 1950-1955 Flying Cloud 9 03-14-2010 09:07 PM
Free 1972 Overlander Interior Parts - Get 'em while they are hot (and free) amitchell Interior Restoration Forum 25 03-03-2009 05:02 PM
Vent for Olympian type heaters geezernbabe Furnaces, Heaters, Fireplaces & Air Conditioning 2 01-09-2009 08:14 PM
Propane Refrigerator Vent B Stover Refrigerators 3 10-31-2005 07:02 AM
Help please with Propane heaters Earthling1 Airstream Motorhome Forums 10 11-04-2003 11:29 AM
