Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 01-11-2008, 12:23 PM   #1
geezernbabe's Avatar
Profile:  1970 31' Sovereign
Shingle Springs , California
Vent for Olympian type heaters
We have a Olympian heater in our 23' that was put in by th PO. It works fine and we are going to put one in the 31' we are doing for the frame up. But after reading about the need to vent I was trying to figure out what to do with the old holes in the side of the trailer where I took out the old heater and at the same time I was looking at the old ducting that went to the bath that we moved from the rear to the middle of the trailer. So I cut and pop riveted a new duct to fit over the holes and go to the bottom of the side wall where I am going to mount the heater. I will put a small closeable vent under the heater that will supply outside air to the bottom side of the heater. Plus I got rid of some old parts. I will take a shot at some pics it's been a while.
ID:	52395   Click image for larger version
ID:	52397   Click image for larger version
ID:	52399   Click image for larger version
geezernbabe is offline   Reply With Quote
Old 01-11-2008, 12:44 PM   #2
Fyrzowt's Avatar
Profile:  2000 25' Safari
Templeton , California
Images: 8
Looks like that will work!
I opened a window, but this way you'll never forget.
Fyrzowt is offline   Reply With Quote
Old 01-09-2009, 09:14 PM   #3
Dieselgrin's Avatar
Profile:  1973 31' Sovereign
suffolk , Virginia
The PO removed the furnace from my trailer and I am think of doing something similar. any suggestions on flexible venting from the same existing holes? I don't know if the square inches meet the Olympian recommendations.
Dieselgrin is offline   Reply With Quote
Olympian Wave 8 or 8100? Dieselgrin Furnaces, Heaters, Fireplaces & Air Conditioning 1 01-09-2009 11:36 PM
Olympian wave 6 turns itself off pauly g Furnaces, Heaters, Fireplaces & Air Conditioning 7 02-07-2008 09:02 AM
Tow bar receiver type or ball type? Astrodokk Airstream Motorhome Forums 2 06-09-2004 08:20 PM
OLYMPIAN Catalytic Heater 85EXCELLA32 Furnaces, Heaters, Fireplaces & Air Conditioning 1 09-20-2003 11:21 PM
Olympian Catalytic Heater davidz71 Furnaces, Heaters, Fireplaces & Air Conditioning 0 03-26-2002 11:47 AM
