Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 02-24-2009, 07:20 AM   #1
szimmerer's Avatar
Profile:  2008 25' Safari
Canton , Mississippi
Upgrading My A/C.....which unit is best.
I have a 2008 25' Safari with the stock 11,000 BTU Duo-Therm Penguin A/C unit. After six months of use in hot and cold climates I have determined I do not like this unit for a variety of reasons. I am having reliability problems and IMO the 11K unit is grossly undersized, particularly for southern camping (I live in Mississippi). I also do not care for the performance of the strip heater. It must go!
I am considering upgrading to a 15K Heat Pump but I am confused as to which unit would be the best for my 25'. Choices are: Duo-Therm, Carrier and Coleman. Cold producing capability, hot/cold controllability, interior noise and reliability are my major concerns. I plan to have this camper for a long time so cost is important but not my major concern. Any ideas and experiences would be helpful.
Steve and Bonnie
The "Mississippi Queen"
szimmerer is offline   Reply With Quote
Old 02-24-2009, 07:33 AM   #2
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Frozen Tundra , Illinois
When I special ordered my 25' Safari back in October of 2003, only handful of the 25' or larger Classics had the 15k BTU A/C unit as an option. I requested the 15k unit for my 25' Safari. I did receive some suggestions from both folks here on this forum and from the factory (via the dealer) and from the dealer themselves as well not to go this route for a variety of reasons, none of which panned out.
My question back to them was that it was a Classic option, why can't it be installed in a Safari since internal size and construction was the same between a 25 Classic and a 25 Safari (they all start out the same way and get odds and ends added as it goes down the line and becomes a "Classic").
It cost me I believe about $450 to upgrade from the standard LS upgraded unit (13.5k) which was already an upgrade from the 11k unit that comes standard at the time of construction, which most likely won't be your cost doing a total swap out, but you most likely sell the 11k unit.
The 15k Penguin is a great unit. I have zero complaints. Dometic I believe owns and builds the Penguin. In direct sun with high outdoor ambient temps, the 15k unit can keep the inside cold enough to hang meat (ask folks who have been to a rally with me ). The newer models I've heard are even more reliable than my "legacy" model.
I would not hesitate to recommend considering the Penguin low profile 15k unit. Mine has a heat pump, not a strip with it and also has the comfort control system which controls both the A/C and the furnace for seamless service. Even without the Comfort Control System, I would still take a 15k unit every day of the the week and 2x on Sunday.
If you look closely at new models out there for the past several years, many now have the 15k unit (regardless of model) that are 25' or larger with plans to be in warm climate (which is pretty much everywhere these days during the summer months).
Old 02-24-2009, 07:51 AM   #3
szimmerer's Avatar
Thumbs up Upgrading my A/C
Thanks Silvertwinkie.
Yours is the kind of real world and unbiased input that will really help me with my decision.
Steve and Bonnie
Old 02-24-2009, 09:19 AM   #4
Commercial Vendor
Profile:  Corona , California
The new Carrier unit seem to be the biggest choice, perhaps because it has built in oscillating louvers, that really circulate the cool air in a superior way.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 02-24-2009, 09:58 AM   #5
Profile:  1973 23' Safari
1963 19' Globetrotter
Forest , Mississippi
ac for Ms.
szimmerer,
I replaced a older coleman with a Carrier 15.5 hp on a 23' safari. It has worked well for camping here in Ms and a couple of trips to Ft wilderness in florida. The heat pump is generally good to around 36 degrees while camping in the winters and the ac will keep around mid 70's on our july/aug camping trips at Yogi in brandon.
2toomany is offline   Reply With Quote
Old 02-28-2009, 07:49 AM   #6
Chiquita's Avatar
Profile:  1973 Argosy 22
Monroe , North Carolina
Do both of these units have the ability for me to hook my drain hose to them or does the water just run down the sides?
Chiquita is offline   Reply With Quote
Old 02-28-2009, 08:37 AM   #7
Melody Ranch's Avatar
Profile:  1966 17' Caravel
1995 21' Sovereign
1947 22' Liner
Valley View , Texas
Images: 42
drains
They will hook to the drain. By the way, what ever you have ....never accept the water draining down the side.
Old 02-28-2009, 10:41 AM   #8
Profile:  1976 31' Sovereign
Missouri City , Texas
Drain
I think you will need to get a "pan" for the Penguin that has the hook-up to the interior drain line. Maybe others can provide more details on this and where to get it. The Carrier can be modified by installing a small brass fitting in the small pan at the bottom of the fan and then connecting a hose to the interior drain line. It works on the Carrier on my 1976 Sovereign. Here is a picture of the brass fitting looking up from inside with the cover off.
Don
adonh is offline   Reply With Quote
Old 02-28-2009, 03:44 PM   #9
Fan speed
One other thing to consider, I like my Carrier 15,000 BTU AC, it really does cool. But my one complaint is the 2 speed fan/blower. The 2 speeds are high and higher.Tthere is really no low speed when you just want to circulate cool air around without it blowing so hard. It is a little noisy as well since you really don't have a low speed. Other that that on hot days it will keep you cool.
Don
Old 03-01-2009, 09:55 AM   #10
Chiquita's Avatar
thanks Got it, maybe the Duo Therm has more speeds
Old 03-01-2009, 12:05 PM   #11
juel's Avatar
Profile:  1978 Argosy 24
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
Have the Carrier 13.5 on my 24ft Argosy. It does a good job, but the noise level is very high. Those oscillating louvers were great for the one season they actually worked. I'm sure I could take it in to have it worked on but living in a small town that means a 65 mile round trip and taking off work to get it to the dealer who installed it. It works fine without this feature, so I never bothered to complain. The big old Armstrong on my 76 Airstream is sure a good unit and makes less noise with more speeds than the new Carrier. Too bad they don't make that unit any longer. Since the Airstream is parked down at the lake while we build our house, we have rigged two household units to vent into the front and rear access doors under the frig and under the back twin bed. They make for no noise inside the trailer and talk about hanging meat! The new frig was put up on a platform that allows the A/C to blow under it and a vent was installed in the front of the platform to allow cool air into the trailer. We love it, it didn't mean we had to destroy anything on the Airstream and they are taken out in the winter and stored.
ID:	76259   Click image for larger version
Judy and Bob
At Home in Oklahoma
juel is offline   Reply With Quote
Old 03-01-2009, 01:50 PM   #12
Chiquita's Avatar
Don't the drain pans come with the unit? Are the drain pans contoured for the curved roof top? I think I am going to go with the Duo-Therm Brisk Heat pump 15k. My head is aching going back and forth with this.....
Old 03-01-2009, 02:18 PM   #13
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 62
This morning I ordered a 13.5 Low Profile with the heat strips option from Family RV in Florida. Total cost with shipping to Phoenix was just under $700. I was going to fix my original Armstrong, but found that the shroud is missing pieces and has some serious cracks as well. The new Carriers attach to the drain line in the trailer also. I start the install after the unit arrives next week, now where are all my friends...
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Old 03-01-2009, 03:00 PM   #14
Tramp Streamer
Commercial Vendor
ArtStream's Avatar
Profile:  1995 28' Excella
Artist , at Large
Images: 65
Smile What a drip
Drain pans are ordered separately. During removal the old ones usually get damaged. When I ordered my Duotherm I also ordered a new drip pan. You will be amazed at just how thin the plastic is.
I remember Andy posting something about a brand that slung the water somewhere and so did not need a drip pan, Andy?
Airstream Posters & Tee's
by Micheal Joseph Depraida
WBCCI No 8892 | VAC | KC2TQU
ArtStream is offline   Reply With Quote
Upgrading my windows Cathy&Pete Windows & Screens 2 08-19-2007 03:34 PM
upgrading the Univolt mikeandbecky Batteries, Univolts, Converters & Inverters 18 07-30-2007 03:35 PM
Pensacola Unit vs. Big Bend Tallahasse Unit gypsymoth WBCCI Forum 14 07-06-2007 10:16 AM
shopping for a unit to join at unit rallies Spartan WBCCI Rallies & Events 36 11-30-2006 04:01 PM
Some upgrading on our 72 Overlander Silver Threads Upholstery, Blinds, Walls & Interior Finishes 3 09-01-2006 09:28 AM
