Old 08-19-2010, 05:57 AM   #29
1966 20' Globetrotter
1993 34' Limited
Hugo , Minnesota
Just passing thru on the way home. Stay cool! Little Rock area is prettier than I expected. Lots of rolling hills and nice highways. Thanks for the reply.
fstuneck is offline   Reply With Quote
Old 09-02-2010, 02:27 PM   #30
AirHedz's Avatar
2010 31' Classic
Keller , Texas
We have had our '10 31 Classic on the Texas Gulf Coast for the past couple of months. Temps have been in the low to mid 90s, but the humidity has been 80%-100%. With just one 15K unit it is definitely (as an earlier poster said) an uphill battle. We have considered adding a second unit, but at a cost of over $2,000, and with all of the other issues we have experienced we will just have to deal with it. Next year we plan to not use the AS during the hot time of the year.
On the other end of the spectrum, we towed our AS to Yellowstone NP during the last week of May. Temps were anywhere from 30-50, and we almost froze to death. It's a good thing we are both well insulated because our AS is not. Even with the use of an electric space heater, we still burned a whole 40 lb. tank of propane.
AirHedz is offline   Reply With Quote
Old 09-02-2010, 04:22 PM   #31
richinny's Avatar
2011 34' Classic
have you considered having the trailer pressure tested for big air leaks? a lttle draft can go a long way in changing the inside climate.
Ricky
Old 09-02-2010, 07:07 PM   #32
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Originally Posted by Frody View Post
If that barrel fan will not rotate, grip it and firmly apply pressure trying to wiggle it back and forth. Eventually you should be able to free it up so it spins freely.
Once the barrel is moving freely, plug your trailer back in to 110 power and turn fan knob to low. Should work, if so, reassemble.
Mechanic also said there is another fan on the opposite end of the barrel. To get to that other end, have to go through the roof. Haven't had to do that, and hope not to.
Mechanic told us to run that AC/Heater once per month whether we are living in it or not. Doesn't take much for fan shafts to lock up.
Look up TXIcemans trick with a broom handle. On his Dometic he sez he believes (as I recall) that a sticking shaft is the usual culprit, and that it needs to be moved every few weeks. He may access his from roof. Posts here, but mainly on IRV2 (Another Silver Streak owner, with a "new" Avion in the shed).
15k is minimum in Texas. We fulltimed seven months in 2007 in Texas from May to December. A/C was off only to move to another site (another city); ran non-stop, essentially, for seven months.
Keep an eye on voltage; plug vents, use awnings, install curtains with a blackout liner (and use similar to reflectix); mainly park in afternoon shade. While our Silver Streak had better insulation/construction than an Airstream, heating up that metal takes a toll. (Streamline painted their roofs white from the factory for the very reason of heat rejection, and there are A/S owners who have done likewise). The amount of glass area to floor square footage ratio is high (poor on an SOB, but, that's life on a hot day). I also bought a small (cool looking) oscillating table fan from RESTORATION HARDWARE in Dallas (Galleria) and this was a good help. I also removed A/C and installed a better gasket, and went for a better filter (Camper Capitol, on Forest Lane).
This problem alone put a HUGHES Autoformer (or other brand) high on the list for the next trailer as low voltage on a 106F day is a lousy proposition (dual A/C WILL be on the next one, with a mod to a 50A system to handle it).
On the hottest days (hell, weeks) in Dallas we had all the curtains shut until latest evening. I found all the hot "leak" spots around doors and windows and did some fixin' . . an IR gun is your friend. Also did cooking in morning or outside. Sounds like a pain to an non-RV'er but that's part of the fun. Don't forget that trailer leveling can torque the door frame slightly (air gap). And that age causes window gaskets to shrink (research this topic).
We hibernated in the afternoons when no appointments called.
Interior storm windows were an option on Silver Streak, and on Avion, and they are also high on my list for summer weather (as well as low-key, non-attention-grabbing insulation pieces for vents and windows that appear professionally-made).
Our windows were a smoked glass. I have read of some "success" by others with heat reduction by having high-zoot film applied. (Plenty to study here).
Don't forget refrigerator performance. I sold my trailer short of installing a SNYDER vent fan modification kit. (Also, see threads on hotrodding the stove vent fan operation).
When not in use I had a portable de-humidifier in constant operation. Found it was not hard to store, and that the trailer benefitted from it's use on marginal days where humidity was the greater problem than heat. A few hours operation in morning was enough that the A/C didn't work so hard the rest of the day to keep things dry and cool.
No such thing as too much A/C down here. I recently went through some detailed lists of how to calculate A/C needs for houses (Manual J and the like) and had a laugh at what was "revealed". My 1,800 s/f house has 5-tons of A/C . . considered normal by local, long-time contractors; twice what government calculators estimate. What works in Illinois or Nevada just don't matter here. (A new house system might be less tonnage, but more expensive due to other add-ons).
Good luck
Old 09-02-2010, 07:19 PM   #33
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Sounds discouraging. I'm third gen on this trailer type. Problem-solving is half the fun of being independent (yes, all these trailers are energy hogs in hottest or coldest weather). If you investigate around here you'll find ton's of workarounds, stopgaps and outright fixes. An electric bedwarmer and eiderdown comforters are great (as is wool long underwear).
Same token on the coast. The wet bulb temperature of 95F is considered dangerous at a point in time for humans. We locals from "hotter climes" learn to add 12F to the local temp for an understanding of humidity. A portable de-humidifier from LOWES does the trick. Keep the doors closed, too. While it's true that with shade and a breeze that the Gulf Coast is bearable where North Texas is not, the humidity is an insidious enemy. Shade and humidity control are everything.
Research the topic of adding a second unit. You can probably get away for less than that if DIY (though maybe not much). As you could -- more than conceivably -- keep the trailer for a quarter century, that modification is cheap on an annual basis. And a huge selling point.
Again, TXIceman did the conversion himself on his new '89 Avion; PM him for insight.
Ya'll ain't over in Rockport are you?
Best
Old 09-03-2010, 02:27 PM   #34
AirHedz's Avatar
2010 31' Classic
Keller , Texas
Yes! We are in Rockport!
Old 09-04-2010, 09:21 PM   #35
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Greatest place on the Texas coast. Someday it'll be unaffordable for us mere mortals. Glad the temps have moderated the past few days and rain is on the way hallelujah!
Be sure to check the threads on Padre Island, Goose Island, Aransas, etc.
Take care
Old 09-04-2010, 11:08 PM   #36
SipStreamer
2010 20' Flying Cloud
Lakeside , Montana
We have a very simple, but highly effective cure for high heat problems. We moved to Montana.
StreamDog is offline   Reply With Quote
Old 01-14-2011, 11:53 PM   #37
DAHarvey
2002 22' International
2004 22' International CCD
2010 25' FB Flying Cloud
Johnson City , Texas
I have a 2010 25FB Flying Cloud and it came with a 13500 btu. Last summer, in the Texas heat when it was 100 degrees outside the best I could get the trailer was around 89 degrees. Our friends right next to us, same conditions and same size trailer, but much cheaper FunFinder had the inside temperature well below 80 degrees. As soon as I got back from our trip, I had the 13500 btu replaced with a 15000 btu. Next trip it barely made 2 degrees different. I have been told to cover the windows, stay in the shade, get awnings, stay off concrete and asphalt, keep the door close, etc.
My previous 2 airstreams never had this problem. I personally think maybe the newer airstreams have a lot less insulation.
Anyway, once summer gets here, I will start trying to get the issue resolved again, I think I might have to get a 2nd 15000 btu ac put on! And buying a FunFinder is not an option!
daharvey is offline   Reply With Quote
Old 01-15-2011, 06:36 AM   #38
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Does your new FC have an exposed aluminum ceiling? If so, that's where the extra heat is coming from. That metal gets warm, and it does radiate into the interior. Airstream listened when they got complaints about the padded headliners, they fell, got dirty, etc, and the all-aluminum looked better, so they pretty much got rid of it. The trade-off is a warmer interior in Summer, and cooler in Winter. Also, that headliner was also an additional layer of insulation.
Of course, all this is assuming you had a headliner in your last Airstream, and don't have one in this one.
Old 01-15-2011, 06:58 AM   #39
Dwight's Avatar
1999 34' Excella
Joshua , Texas
Which model of portable de-humidifier from LOWES did you guys get.....I see from their web site, they have several to choose from.....
History doesn't repeat itself, people do!
Dwight is offline   Reply With Quote
Old 01-15-2011, 08:14 AM   #40
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Checked the Lowes site. The cheapest one is what we bought, but the brand is now different (ours was 2007). $150 is what I paid, as I recall.
I set mine up on the kitchen sink counter and ran drain hose to that. After several months storage in high humidity took 10-days to dry out trailer completely. Left all cabinets, closets, open.
Old 01-15-2011, 08:54 AM   #41
DAHarvey
My previous trailer had the exposed aluminum on the inside as well. It was a tad smaller, however, it stay extremely cold even in 100 plus degree Texas heat. I do think with all the windows, skylights, and exposed aluminum that Airstream would test their product in real weather conditions. And keep in mind most RV parks that we go to, have concrete and no trees. It would as be nice if airstream would have pre-wired all units for two ac, knowing that a lot of their trailers will be going in and out of the Texas heat. Because we were able to sell the 13500 btu ac that we had replace with the 15000 btu, it only cost us about $900. But our issue is still not resolved!
Old 01-15-2011, 08:59 AM   #42
Our 2004 Safari with a padded plastic headliner and mouse fir walls is comfortable to 110 degree outside temp with the bottom of the line 11k btu Penguin. It pulls the interior temp down over 25 degrees.
It sounds like the problem is that fancy all aluminum look of the newer Airstreams further reduces the already minimal R factor. Ours looks ugly but we don't swelter in the summer.
We still shiver in the winter, however
Rather than upgrade air conditioners, is it possible to add insulation in some manner that wouldn't spoil the looks of that classy interior? Or perhaps add some kind of a sunshade for long term camping?
handn is offline   Reply With Quote
Tax info on upgrading Airstream Mackhopp Local Regs & Licensing 27 05-11-2011 07:04 PM
Old Camper but Brand New Airstream! Lindsey Member Introductions 9 05-10-2010 03:27 PM
upgrading airstream with argosy front window turfclubroad Windows, Doors, Locks & Vents 5 03-17-2009 10:58 AM
Airstream trademark and brand Buttercup Airstream "In the News" 0 03-10-2006 10:01 AM
Brand new Airstream owners! WolfSong Our Community 10 07-24-2003 08:22 PM
