Old 06-30-2016, 11:28 AM   #1
Brisbane , Queensland
Cool Underfloor hydronic heating.
Does anyone have experience with using underfloor hydronic heating in their Airstream?
The new Classic has introduced hydronic heating using radiators with an Alde furnace/water heater.
This new design seems clumsy in that it requires an unwelcomed gap between the kitchen counter and the inner wall to allow heated air to rise from a radiator that is positioned on the floor behind the base cabinets.
Also, previous posts have mentioned the loss of floor space do to other radiator fixtures that are place on the floor along the interior wall's perimeter.
Is it that Airstream thinks an hydronic underfloor system using the same Alde furnace is too complicated or too difficult to design and maintain, or is it a case of timidity in introducing something 'new'.
Love to hear the forum members thoughts on this 'new' heating/continuous hot water system.
DaytonaDan is offline   Reply With Quote
Old 06-30-2016, 12:50 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Just another thing that will ad to the weight of the coach. Is the heating fluid water or something that won't freeze if there is no heat?
Old 06-30-2016, 01:20 PM   #3
Wise Elder
Jammer's Avatar
2010 30' Classic
Neither. It doesn't work, laws of physics get in the way. There isn't enough floor area in an Airstream to transfer sufficient heat to keep the trailer warm on a cold day, without heating the floor to the point where it's uncomfortable to walk on and hot enough that most common RV floor materials would be damaged.
Malconium, who doesn't post here much any more, tried it, with great effort and some cost, and then discovered that (surprise) it didn't produce nearly enough heat.
Old 06-30-2016, 02:43 PM   #4
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Damn you, physics!
2012 Dodge Durango Hemi/AWD
Old 06-30-2016, 03:07 PM   #5
mandolindave's Avatar
Nope for me
To make the system convenient, and not have to drain it, which would be a hat trick…..the system would have to use a fluid with antifreeze in it, which makes it even less efficient.
A while back, a forum member, used a water heater to heat water that was circulated by a low volume water pump, that ran thru a car radiator, with a fantastic fan blowing behind it to circulate the warm air. He said that it use a lot less electricity that the standard furnaces. I'm thinking that the downside would be the difficulty in directing the warm air to tanks and such.
mandolindave is offline   Reply With Quote
Old 06-30-2016, 03:25 PM   #6
lewster's Avatar
Naples, FL , Hood River, OR
Look at how the Aqua Hot systems are built. Not for their boiler set up but the war they move the heated antifreeze mixture thru the PEX tubing and how they use mini heat exchangers with computer fans to circulate the warmed air.
It's an excellent system that could easily be modified for use with a tankless water heater and circulation pump.
Easy to build, almost silent to operate and could be arranged to heat the tanks too.
Old 06-30-2016, 03:33 PM   #7
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Oak Creek , Arizona
This looked interesting to me and was considering it before I sold my last trailer.
https://www.thermosoft.com/?utm_expi...K9nyu2ZkBrww.0
This is the strangest life I've ever known - J. Morrison
The Nest Egg - 2015 Airstream International Serenity 27FB
Quicksilver - 2017
Chevy Silverado 2500HD Duramax Diesel
mojo is online now   Reply With Quote
Old 06-30-2016, 11:50 PM   #8
1979 23' Safari
Wayland , New York
From a mechanical engineer with an emphasis on heat transfer and fluid flow:
Jammer nailed it, and malconium learned it the hard way.
Some toe kick hydronic radiators could probably work if they were converted to 12v fans.
Old 07-01-2016, 06:34 AM   #9
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
We have hydronic in-floor heat at the S&B house and love it. As a result I understand very well how it works, it's strengths and limitations. It would not work well in an Airstream for all the reasons previously mentioned. This is a solution looking for a problem.
Did someone mention that the new Classics come with this "feature?"
Bob Martel
WBCCI# 5766
Old 07-17-2016, 12:37 PM   #10
rodsterinfl's Avatar
2006 25' Safari
Fort Myers , Florida
Images: 8
I just watched the Colonial Video on the new 2017 Classic and then read a How it works pros and cons of Hydronic Heating/Cooling versus Forced Air Heating Cooling.
I am surprised that Airstream would use a water based system (glycol) in the trailer with a wood floor. The article shared how that all over Fairfax county homes with hydronic heating and PEX plumbing sprung leaks at all different fittings. Additionally two of the issues mentioned were how quickly the efficiency dropped over age/time and the slow response of the system converting through a heat exchange system. There was a sub section on how homes have started going with glycol-based systems or adding glycol to some systems but that expansion was an issue to be aware of for fittings, etc. The article was thorough but it described it as a system with multiple concerns for few benefits- those being lack of noise, more even heating and stable humidity. It mentioned one outstanding issue by regular homeowners as being unable to spot heat and having more difficulty regulating temperatures in transitional weather seasons like fall and spring.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 07-17-2016, 01:52 PM   #11
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
I had it in a home in NY, brazed copper pipe system. After I had lived there two years I had a wet carpet and could not troubleshoot. thought it was a roof leak and chased that too long. Finally I determined it was the heating system by isolating it. Then I had to cut through the wall and found that a trim finishing nail had penetrated the copper pipe but took 2 years to corrode enough to leak. Repair was not too hard but I am happy to have the simplicity of forced air heat where I live now...and in my Airstream.
Larry
lsbrodsky is offline   Reply With Quote
Old 07-17-2016, 02:02 PM   #12
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
I cant see there being enough surface area in the AS to effectively heat it well. The system might take the chill off the floor but getting it toasty inside, doubtful! Furthermore, what about the tanks?
Old 07-17-2016, 02:04 PM   #13
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
I looked carefully at the system in the '17 Classic. While it might be nice not to have furnace and water heater vents in the side of the trailer, I was not taken with the amount of wall space dedicated to the system. The guts of the system are located under the forward dinette seat. While the forced air system is noisy and the distribution system is far from even in my trailer (the two vents facing the sofa put out huge amounts of hot air -- the ductwork and registers are only about 18" from the furnace -- the BR and bath are pretty meager. I didn't much care for the enormous heated towel bar in the bath (it's how the heat in the '17 is distributed in the bathroom), but my largest question has to do with the battery power necessary to heat the electric tank heater pads. I was told these come on automatically at 40 degrees. Will be interesting to see how the "pioneers" with this system like it.
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Ghetto Hydronic Heater ericpeltier Plumbing - Systems & Fixtures 8 05-01-2016 02:36 PM
Underfloor heating. Rob Carey General Repair Forum 13 11-16-2014 12:14 PM
looking for an underfloor blackwater, 63 safari jasoncase Waste Systems, Tanks & Totes 18 07-17-2009 10:16 PM
Problem with '84 345 with hydronic heating!! joegooch Member Introductions 5 03-04-2009 09:06 AM
Underfloor Water Tank muddy_hollow LP Gas, Piping, Tanks & Regulators 8 01-25-2007 03:00 PM
