Old 01-22-2011, 11:53 PM   #1
1958 18' "Footer"
Condon , Montana
underfloor heater
I have a 1959 18 foot model with an underfloor heater. It looks ok but I am wondering if these are decent heaters, worth messing with. I have never used this one. Would it be better to update and if so, what is recommended. Anyone have any ideas?
Tom
tosten is offline   Reply With Quote
Old 01-23-2011, 04:20 AM   #2
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
I had a floor heater in an old Garway trailer. It worked well, heating the 14 footer in zero weather however the grate in the floor will get hot enough to leave a grid pattern on the soles of your shoes. Don't go barefoot.
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 01-23-2011, 06:22 AM   #3
1958 18' "Footer"
Condon , Montana
Thanks! I think I'll connect it and give it a try while I am working on the trailer. Do you know of any links that will give me more info? Do you see it as a fire hazard?
Old 01-23-2011, 06:45 AM   #4
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
I am hesitant to make any claims as to fire safety etc. beyond saying we had no problems.
It should be kept in mind also that I had this trailer around 1969 and it was only 5 years old at the time.
In a small trailer it is a good idea to allow a little ventilation even if the heater is in good shape and vents outside.
We had a house furnace failure in zero weather and all 3 of us went to the trailer to keep warm ( the 14 ft with the floor furnace) It was a windless night and the trailer was buttoned up tight. In the morning we all felt bad, especially my 9 year old daughter.
Suspecting carbon monoxide, we went to the Dr. He told us that what had happened is we were suffering from the affects of Carbon Dioxide as we had essentially used up the oxygen in the trailer. Probably would not have happened if we had a window cracked or even if the wind had been blowing that night. Apparently a combination of the still night and 3 people in a very small trailer.
Anyway, just a word of caution for whatever it is worth.
13 Ram 2500 TD
