I could only get barely a hum out of it when we brought her home. Today I was cleaning the ceiling and took the shroud off and found that the fan moved freely. On a whim, I turned the breaker on, went to the control and turned it on. The fan started right up! I turned the temp down and couldn't believe my ears.
The compressor was rumbling! It ran for a bit and then shut off. Hmmmm... While it was decompressing, I went on the roof and shot a bunch of WD40 into the fan shaft and loosened it by hand. Turned the AC on again and went on the roof while it was rumbling and kept squirting WD40 and turning the fan until it finally took off by itself ... slowly at first, and then finally full tilt!
I went inside expecting to just have a lot of noise and little else. Well, you could have knocled me over with a feather blowing in the frigid air coming out ot that thing!!
And it kept running!
It even did it again when I showed my wife after she got home from work!
I feel like I have won the lottery!!
36 years old and it still purrs like a kitten!
They sure don't make'em like they used to!
Now I have toclean and lubricate it well and try to find a shroud for it .. the one up there has a couple of holes in it, but that's a lot better than putting a new AC up there!
P.S. Anybody know where you can get a shroud for an Armstrong TR21-12 ?
