Old 12-05-2014, 10:33 AM   #1
1977 31' Sovereign
Indianapolis , Indiana
Unattached vent under sink
Name:	ImageUploadedByAirstream Forums1417800568.255411.jpg
The vent pictured leads into the belly cavity of the camper. The fresh water tank and intake use the same hole on the floor.
I need to heat this compartment for winter camping. I assume I can reconnect the vent to a furnace duct. Any suggestions for best method?
jasonsherman is offline   Reply With Quote
Old 12-05-2014, 10:42 AM   #2
dznf0g's Avatar
Oswego , Illinois
First question: I can't tell from the pic if you have any available knockouts for additional ducts on the furnace case. If, so there are adapter to go to the 2" duct. That IMO is the best method for delivery of the air to the tanks.
If not, there are 4" to 2" tees which let you feed off one of the 4" ducts pictured.
-Rich-
Old 12-05-2014, 10:46 AM   #3
dznf0g's Avatar
Oswego , Illinois
Reducer:
Venting Products / Boots & Adapters / 4" to 2" Galvanized Reducer/Expander - DW Inc.
and
http://www.dwincorp.com/products/41/...nized-Take-off
or
-Rich-
Old 12-05-2014, 02:38 PM   #4
1977 31' Sovereign
No knockouts. ... Would lowes sell similar items? Thanks
Old 12-05-2014, 03:08 PM   #5
dznf0g's Avatar
Oswego , Illinois
I doubt it. Home ducts are larger diameter
-Rich-
Old 12-05-2014, 03:15 PM   #6
1977 31' Sovereign
Dryer and exhaust fan vents? I'll take a look and post it.
By changing the 4" to 2", will this add stress to the furnace? If so, I can probably figure out a way to split the 4" into 2 2" vents and tie back into the system. If not, I'll just drop 1 of the 4" runs to a 2" and connect it direct to the existing pipe.
Thanks.
Old 12-05-2014, 03:23 PM   #7
dznf0g's Avatar
Oswego , Illinois
Every furnace model has a minimum total outlet square inch spec. Two 2" ducts is less than one 4" in flow rate. If you have to add, do it with the tee.
two 2" ducts = 6.28 sq. in
one 4" duct = 12.56 sq. in.
Don't reduce the flow rate of the furnace below what the installation manual says. It will overheat.
-Rich-
Old 12-05-2014, 03:32 PM   #8
dznf0g's Avatar
Oswego , Illinois
Are you sure there aren't more knockouts? Mine had 6 or 7. Look on all three sides. Mine had 2 on the back, and 3 on each side, as I recall. I added an extra run to the bedroom and just used the knockout and one of the collars listed above.
What furnace model and brand?
-Rich-
Old 12-05-2014, 03:34 PM   #9
dznf0g's Avatar
Oswego , Illinois
Venting Products / Boots & Adapters / 4" Tee With 2" Outlet - DW Inc.
somehow my copy and paste didn't show the tee I was talking about. Try this.
-Rich-
Old 12-06-2014, 04:21 AM   #10
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
dznFog, Good job. You helped jasonsherman perfectly in my view. Now I know where to go if I have a furnace question!
David
Old 12-06-2014, 06:25 AM   #11
1977 31' Sovereign
Thank you. I'm away from the camper for a few days, but will check for knockouts and furnace brand/model on Tuesday.
....lots of good info.
Old 12-06-2014, 07:19 AM   #12
dznf0g's Avatar
Oswego , Illinois
Just as an FYi, On my unit the 2" line for the FW tank is in the same location as yours. Mine (because of extra knockouts) is connected directly to the furnace. I have a separate 2" duct for the B & G tanks and it utilizes one of the Tees above. It tees off the bedroom 4" duct under the wardrobe floor and enters the belly where my water lines come up.
-Rich-
Old 12-09-2014, 09:18 AM   #13
1977 31' Sovereign
Name:	ImageUploadedByAirstream Forums1418141836.578597.jpg
Here's the photo of the furnace details.
It's a suburban furnace.
'71 23' Safari Twin Forced Hot Air Vent under kitchen sink Kei Airstream Classifieds 0 06-02-2014 10:07 PM
One sink, two sinks, red sink, blue sink? Janet H General Interior Topics 7 07-26-2006 06:17 PM
Need a Water filter under sink w9det Water Heaters, Filters & Pumps 7 06-29-2005 06:15 AM
Under sink cabinet [What's this ?] niftypkg Cabinets, Counter Tops & Furnishings 2 12-14-2002 01:26 AM
Globetrotter 1963 - Kitchen Sink Drain Leak Under the Floor Uncle_Phil Plumbing - Systems & Fixtures 3 08-09-2002 06:59 PM
