Old 11-25-2008, 10:15 AM   #1
BrockLives's Avatar
1972 29' Ambassador
Currently Camping , Pennsylvania
Question TwinTemp Jr. feasibility & new Suburban heater questions
I've been told that in-floor radiant heat would not work in a trailer because the flooring would insulate the heat away from the inside. How much truth is there to this? What kind of performance could I expect from a TwinTemp Jr? (PrecisionTemp.com: For Recreational Vehicles and Boats) I do know about the VAP podcast that installs one of these but I can't view it
Secondly, if a TwinTemp Jr would work, and I wanted to stay in below freezing conditions, would I still need an auxiliary furnace?
Thirdly, does anyone have any experiences with the Suburban SH furnace (the 'quiet' ones: http://www.rvcomfort.com/suburban/pr...naces/sh.php)? How noticeable is the noise difference between that and the SF or NT?
I know next to nothing about heaters, so please don't worry about being too pedantic in replies Thanks in advance.
BrockLives is offline   Reply With Quote
Old 11-25-2008, 02:26 PM   #2
1975 29' Ambassador
Reno , Nevada
There have been threads about several folks who have built hydronic systems for their trailer (search with keyword "hydronic"). RV Hydronic Heating System is a homebrew approach for this.
The TwinTemp the VAP used is rather expensive and it comes with heat exchangers and blowers. You might need to be aware of its through floor venting if you are using siding in cold weather. It is also an inline 'tankless' water heater if I understand right - should be significantly more efficient than a standard furnace and hot water heater.
The heat exchange and blower idea could be used to feed your existing tank heat ducts so an auxiliary furnace shouldn't be needed. That usually isn't that big a deal, anyway.
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 07:17 AM
suburban ductless heater DD urbanfood Furnaces, Heaters, Fireplaces & Air Conditioning 1 08-21-2007 05:48 PM
Atwood to Suburban Water Heater Sundance Water Heaters, Filters & Pumps 11 07-11-2007 10:40 AM
Water heater prob, pilot won't stay lit & heater won't fire. johnboy Water Heaters, Filters & Pumps 1 06-20-2006 04:24 PM
Suburban water heater (might) flame on 74Argosy24MH Water Heaters, Filters & Pumps 0 05-25-2005 02:51 PM
