Old 10-28-2007, 04:04 PM   #1
wayne.yl's Avatar
1977 31' Sovereign
1992 34' Excella
Salem , Oregon
trouble with suburban furnace
This weekend we took the trailer out and had to use the furnace.
It ran fine the first night but on the 2nd night I noticed the fan coming on and then going off immediately. When I set the thermostat to a warmer setting the fan would come on and stay on until the cycle was complete. Any thoughts why I needed to adjust the thermostat to a warmer position before it would work right?
Wayne
wayne.yl is offline   Reply With Quote
Old 10-28-2007, 04:24 PM   #2
lewster's Avatar
Naples, FL , Hood River, OR
Wayne
Wayne,
Might be a problem with your thermostat or the igniter board of the furnace. I would check the t/stat first as this is far cheaper to replace than the board.
Remove the t/stat from the wall and find the 2 blue wires. Connect them together and see what happens. If the furnace comes on and heats, and stays on until you disconnect the wires, your board is probably OK and the t/stat should be replaced. If not, then it's probably the board.
If you do need a board, I strongly recommend getting a Dinosaur UIB small for your furnace. They are the BEST and have a 3 year warranty.
Old 10-28-2007, 04:28 PM   #3
wayne.yl's Avatar
1977 31' Sovereign
1992 34' Excella
Salem , Oregon
Lew,
I just finished reading your comments on the other Suburban thread about the Thermostat blue wires. Thanks for helping out.
I will check it out and let you know.
Old 10-28-2007, 04:55 PM   #4
wayne.yl's Avatar
1977 31' Sovereign
1992 34' Excella
Salem , Oregon
Thermostat?
Lew,
The test went fine. I disconnected the two blue wires and pigtailed them together. the Furnace came on, heated up and stayed on until I disconnected the blue wires.
I will replace the thermostat and see if this corrects the problem.
thanks again for diagnosing this issue.
Wayne
PS... are there better thermostats than others?
Old 10-29-2007, 08:16 AM   #5
lewster's Avatar
Lew,
Wayne
There are better ones out there, but they are generally not compatible with the RV-type furnace, as most of the domestic systems work on AC rather than DC current. There are electronic versions, but they require a compatible air conditioner, as the control board of the A/C unit actually controls the furnace as well (convoluted I know, but that's how the design goes).
They are pretty cheap, so I would just replace it and not worry until it goes south again. At least it's accessible!!!
Old 10-29-2007, 08:42 AM   #6
RBolton's Avatar
Belington , West Virginia
I'll jump in here with a thermostat question rather than starting a new thread.
The thermostat on my 75 Argosy looks to be the original . It does not seem to have an off position. If I set it at its lowest, far left position, the furnace will come on when the trailer temp reaches 55 degrees or so.
I place a small piece of cardboard between the contacts in the thermostat to prevent it from coming on. I guess I could wire in a switch, but it looks like there should already be a way to turn this off. Any Suggestions?
Roger
RBolton is offline   Reply With Quote
Old 10-29-2007, 03:01 PM   #7
PizzaChop's Avatar
1973 31' Sovereign
Danielsville , Georgia
Images: 202
Any Suggestions?
New furnaces usually come with new thermostats.
Ron Kaes
Psalm 112
www.paparonnis.com
PizzaChop is offline   Reply With Quote
Old 10-29-2007, 05:07 PM   #8
RBolton's Avatar
Yes, and I suppose a new trailer would be the easiest way to get the new furnace.
I don't know what I said to warrant what seems like a smart aleck reply. I don't believe a new furnace is the answer. The furnace works great. I was only inquiring as to whether or not this is the proper operation of the original thermostat in that it does not have an "off" position or if I am overlooking something.
Thanks in advance for a helpful response, Roger
Old 10-29-2007, 06:15 PM   #9
lewster's Avatar
Roger, The new t/stats all have an on/off switch. You have several choices like White/Rogers, Atwood, Suburban and probably a few off brands. Your local RV Parts supplier should have them and they should be a direct replacement for your original.....$20-30 and you're good to go!
Old 10-29-2007, 08:15 PM   #10
PizzaChop's Avatar
1973 31' Sovereign
Images: 202
RBolton,
My deepest and sincerest apologies for the offense. It was with lightness of heart, not smart aleckness that I responded to your inquiry.
I'm sorry that it didn't seem that way.
I have replaced two 70s era furnaces and have seen the inside of them.
I have a neighbor who passed away 3 years ago from a faulty RV furnace and there was a recent thread with a link to an article of a couple and their grandchildren who died in a horse trailer from CO poisoning as well.
When I first removed my furnace and took it to the local RV shop, they attempted to fix it (had a bad/leaky valve) and even spoke with Suburban about it, when they were instructed to pitch the furnace, as it was over 30 years old anyway.
I took their advice.
From here on, I'll keep my thoughts to myself.
Best of luck with your thermostat...I never did put the new one in which came with the new furnace, but I think I should've have, as I'm not sure it was working quite right this weekend!
But I do agree with you in that a new trailer would be the easiest way to get a new furnace!
Ron Kaes
Psalm 112
www.paparonnis.com
Old 10-29-2007, 11:13 PM   #11
RBolton's Avatar
Ron,
I appreciate your concern for safety. I have read several posts concerning the older furnaces and have had mine inspected and am comfortable with it. I don't know if it is the original, although it is certainly not very new. I do believe the thermostat to be original though.
I have installed a CO alarm (high) as well as a propane detector (low.)
Lew,
Thanks for the info on the thermostats. The piece of paper trick is a bit of a hassle and I have forgotten to use it in the past only to return to the trailer mid-day and find the furnace wasting battery and propane while no one is around. At $20-$30 for a new t-stat it would not take long to pay off.
Roger
Suburban furnace pjude General Motorhome Topics 4 10-16-2007 08:00 AM
Suburban furnace 34 NT pjude Classic Motorhomes 3 07-29-2007 10:06 AM
Trouble shooting Furnace/Heat Pump/Air C? Kistler Furnaces, Heaters, Fireplaces & Air Conditioning 8 01-07-2007 12:13 AM
Furnace Trouble In Vt elliottkatz LP Gas, Piping, Tanks & Regulators 1 12-31-2006 12:27 PM
NT22 furnace trouble wfdyer Furnaces, Heaters, Fireplaces & Air Conditioning 2 01-25-2004 07:00 PM
