Old 07-25-2014, 09:23 AM   #1
Rustington , Sussex
TR21-12 compressor fan problem
I have the above A/C fitted to my '73 Overlander which has been working great until today. The fan on the compressor runs for about 20 seconds then there is a click and it slows down before speeding up again. Any ideas guys?
Jimbo1973 is offline   Reply With Quote
Old 07-25-2014, 10:47 AM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
On ours, the spacer shim under the armature had worn out, and allowed it to drop out of alignment. The fan slowed down almost to a stop, then it shut down from high head pressure. I made a new shim out of an aluminum washer.
Old 07-27-2014, 02:36 AM   #3
Rustington , Sussex
Ok thanks. I think something is triggering a solenoid which reduces the fan speed and then it starts speeding up again.
fan operates, but compressor won't kick on tinsltootsie Furnaces, Heaters, Fireplaces & Air Conditioning 9 06-14-2017 03:25 PM
Correct Capacitors for Armstrong A/C fan & compressor Danny Bell Furnaces, Heaters, Fireplaces & Air Conditioning 0 07-03-2014 12:10 AM
AC Compressor works-no fan!! pappy19 Electrical - Systems, Generators, Batteries & Solar 5 10-05-2012 07:45 PM
AC Fan runs, compressor does not turn on JW84345 Furnaces, Heaters, Fireplaces & Air Conditioning 8 07-06-2009 04:37 PM
Hello, looking for a schematic of the wiring in my Armstrong AC model TR21-12, DMC Member Introductions 1 07-10-2007 06:11 AM
