Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 07-12-2005, 03:40 PM   #43
Minnie's Mate
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
Profile:  2006 30' Safari
Fayetteville , Georgia
You might have the A/C repairperson check the voltage at your site and at any site that might be empty to see if it is better especially if he/she is there late in the afternoon when everyone's A/C starts kicking into overdrive. Then you can request a different site. This would be a free solution and would beat buying a patio awning that might not be welcomed in an rv park. You could still invest in the Autoformer if you plan to be in Arizona next summer, but at least you could save the repairs made this year until it arrived.
Old 07-12-2005, 03:53 PM   #44
joatmon
Profile:
More Audio Alerts
In addition to the aftermarketers offering a breakaway switch which offers an alarm when the lanyard is pulled (in case some... person pulls the lanyard as a "joke"), it would be nice if Airstream or someone else offered a plug-in voltage monitor which audibly alarmed when it was unsafe to run the AC.
A well designed unit would take into account the start-up surges of your own unit, and momentary spikes in the campground's loops.
joatmon is offline   Reply With Quote
Old 07-12-2005, 04:47 PM   #45
markdoane
Profile:  , Minnesota
Images: 59
You could run the power through a large inverter/charger. Might cost a couple of thousand $, but you would always have clean, 120volt power.
Non-contributing deadbeat.
Old 07-12-2005, 04:54 PM   #46
norbert
norbert's Avatar
Profile:  1993 30' Excella
chicagoland , state of confusion+north of cheddar curtain
Images: 24
minnie you,
the owner knows...its called $$$$$$$$
Illegitimous noncarborundum(dont let the bastards wear you down)
The only true nobility is found through giving good food to your friends- Anton Careme
beauty is in the eye of the beerholder-cosmo fishhawk
if something is too good to be true, its usually gone before i get there-mister boffo
norbert is offline   Reply With Quote
Old 07-12-2005, 05:35 PM   #47
john hd
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
they already do!
my dometic penguin has a red l.e.d. that comes on if the voltage drops to unsafe levels!
john
you call them ferrets, i call them weasels.
Old 07-12-2005, 06:06 PM   #48
joatmon
Profile:
Originally Posted by john hd
they already do!
my dometic penguin has a red l.e.d. ..
Thanks John, but does it make any noise when it is red?
Old 07-12-2005, 06:09 PM   #49
joatmon
Profile:
What is the benefit between your suggestion and the autoformer already mentioned?
Old 07-12-2005, 07:45 PM   #50
john hd
john hd's Avatar
madison , Wisconsin
Images: 40
nope just a red light.
john
Old 07-12-2005, 08:32 PM   #51
markdoane
Images: 59
You'd have a really heavy duty inverter and high capacity battery charger? Can't do that with a transformer.
Old 07-13-2005, 04:11 AM   #52
53flyingcloud
53flyingcloud's Avatar
Profile:  Amherst , New Hampshire
Post Yea, except
Originally Posted by Ferroequine
I have a theory that now that I've polished the trailer, it should actually be a few degrees cooler inside than before, due to all of the heat bouncing back off it with the reflection -- sorta like the space wrap they put on sattelites.
Can anyone else confirm?
The "space wraps" are made from very thin sheets of GOLD. Its primary use was and still is for the discharge of static electricity.
In the very earliest days, the static discharge was due to the buildup on the satellites passing thru solar winds and, the resulting discharge of static electricity was extremely destructive.
Also
To properly cool an objection in space, you need to rotate the object at a specified rate of turn so that no one side becomes unduly hotter than the other. Other tricks are employed by the Space Shuttle when its cargo bay doors are left open in the extend position to act as a cooling fins.
ciao
53FC
53flyingcloud is offline   Reply With Quote
Old 07-13-2005, 08:04 PM   #53
Minnie's Mate
Originally Posted by norbert
minnie you,
I was trying to be polite and give 'em the benefit of doubt. I figured the owner new and didn't want to put out the dough to fix it.
But changing sites might elliminate the problem for the rest of the season or at least until a more mobile solution could be secured.
Old 07-13-2005, 10:39 PM   #54
Ferroequine
Ferroequine's Avatar
Profile:  1975 23' Safari
Calgary , Alberta
Oh well
So much for my theory. Maybe I'll still "look cool" though...
Interesting information, nevertheless.
1975 Safari 23'
2004 Ford Expedition Eddie Bauer 4x4
Ferroequine is offline   Reply With Quote
Photos from the St. Patricks Day Rally @ Desert Star Ranch Andy R Forum Rallies 4 03-21-2005 11:07 PM
Rallies for M - F working class in SoCal GoldFever The Rally Zone 54 12-10-2002 11:54 AM
Texas Minuet Chas All Argosy Trailers 14 12-04-2002 06:53 AM
Wipe on Shiny stuff smily Cleaning, Stripping & Polishing 5 09-05-2002 07:54 PM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
U2 Forums
