Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 08-16-2007, 06:07 PM   #1
goransons
goransons's Avatar
Profile:  1969 25' Tradewind
1963 22' Safari
Yakima , Washington
Question tomorrow's the big day
Tomorrow if all goes well the new carrier low profile goes on the roof of the 69 tw. I checked with Andy at Inland RV and he instructed me to the location of the wires, which were easily within reach of the measurement. I was however surprised that after cutting the hole and plugging the trailer back in, that the wires were only capped with nearly 40 year old masking tape and were hot (found with a circuit tester). I did some more investigating to find that at some point the PO had re-ran another main line from the univolt to the main 30 amp breaker, then jumpered from the 30 amp breaker to the frig receptical. So I'm returning it back to stock wiring, however I discovered that the bottom 20 amp breaker by the front control panel (not the main 30 box by the hot water heater) controls the A/C lead. Is this what others have encountered? My assumption was that the A/C power feed came in next to the 30 amp trailer main on a seperate lead. Help appreciated!
goransons is online now   Reply With Quote
Old 08-16-2007, 07:42 PM   #2
vswingfield
vswingfield's Avatar
Profile:  1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Rivet New Carrier AC
Glad you found it with a circuit tester!
Which Carrier did you get? One is my highst priority, as soon as I can afford it. Keep us informed. Photos of the install will be greatly appreciated.
Vaughan
vswingfield is online now   Reply With Quote
Old 08-17-2007, 07:11 PM   #3
goransons
goransons's Avatar
1963 22' Safari
Yakima , Washington
Smile A/C Install photos
First and foremost, this being my first time working on an airstream, there is likely better and easier ways of doing it, I just didn't find them before installing! I wanted to make sure it was structurally secure and electrically safe (and of course water tight).
It all became clearer once the install got underway. I cut the small hole last night to find the wires, and spent the time tracking down where wires were supposed to go. I was confused until I cut the hole bigger and could see where the wires were running between the skins.
After making sure all wires were clear I carefully drilled a 3/8 hole in each corner of my marked 14" square on the ceiling, the followed up with tin snips and carefully cut the opening. Once clear I again drilled, this time through the skin the four corners, then climbed the ladder and connected the dots and again cut the skin.
I used 2" aluminum "C" channel to add support. I had to scribe the ends and taper them down a bit so the ends didn't press into the outer skin, then attached both new cross members to the ribs, then boxed to the new cross members to complete all 4 sides. Each connection was made with 2 1" L brackets from the hardware store. A 1 1/2 in hole saw was used to cut a hole on the drivers side for the wiring, and wires passed through with a 1 1/2 rubber grommet.
Once that was done, I had to shim with some of the cut-out scrap to maintain the exact outer skin curve, then secured top and bottom sheet metal to the c channel with 3/16 aluminum pop rivets. Had a friend over for about 10 minutes to get the unit out of the house and on the roof. We use 2 3 legged orchard style step ladders which could be placed parallel at a 45 degree angle next to the trailer (so we never had to climb up there, and didn't have to lean anything on the trailer).
Unit fit great, but noticed the profile in the ceiling trim wouldn't allow for the unit to fit without being distorted. I cut 3 pieces of 1x3 poplar with a 35 degree miter to match the profile. That will later get caulked and painted to match the ceiling (which already had 2 different colors of paint on it when we purchased it).
Torqued unit down until the gasket looked just over half size, and wet the trailer down to check for leaks, none! Trim on for now until painting time. It was 90 degrees today, and the unit had the trailer down to a cool 72 degrees pretty fast while on the low setting.
Hope the pictures help anyone else that was nervous like me. Thanks Andy for the measurements and assistance with location in the ceiling.
Name:	IMG_0738 (Small).JPG
ID:	43423  Click image for larger version
Name:	IMG_0740 (Small).JPG
Name:	IMG_0741 (Small).JPG
ID:	43425  Click image for larger version
Name:	IMG_0744 (Small).JPG
Name:	IMG_0748 (Small).JPG
ID:	43427  Click image for larger version
Name:	IMG_0750 (Small).JPG
Name:	IMG_0751 (Small).JPG
Old 08-17-2007, 07:23 PM   #4
Alumatube
Alumatube's Avatar
Profile:  Jefferson , Arkansas
Awesome! Great job! Pat yourself on the back for that one, AND for taking such nice pics!
Your post will be very helpful for those who have not done this yet (hopefully we never will, since we already have a/c, but you never know!).
Susan
"Despite the cost of living, have you noticed how popular it remains?"
1984 310 Limited Motor Home "The Rockin' A"
1974 31' Excella (soon-to-be carhauler)
Alumatube is offline   Reply With Quote
Old 08-17-2007, 07:38 PM   #5
vswingfield
1967 24' Tradewind
Images: 32
Rivet Nice Job!!!
I’m sure your photos will provide guidance for a lot of people! Karma coming your way.
Vaughan
Photos from the St. Patricks Day Rally @ Desert Star Ranch Andy R Forum Rallies 4 03-22-2005 12:07 AM
Junction, Texas So Llano River SP April 16, 17, 18, 2004 87MH Forum Rallies 12 04-19-2004 01:41 PM
My Stupid Question of the Day.-sink covers 68 Suburban Cabinets, Counter Tops & Furnishings 5 10-11-2002 09:46 AM
Fan-Tastic fan??? definition needed hex Our Community 26 10-10-2002 03:17 PM
My repair day 3/9/02 1985air345 Airstream Motorhome Forums 8 03-10-2002 05:29 PM
test
