Old 02-21-2013, 11:56 PM   #1
1984 31' Excella
Turlock , California
Therm'X model 635 Catalytic heater
I've had lots of trouble getting the heater to light. It flames up and down the surface but will not stay lit when I rotate the knob from pilot to low or high. I've held the button in for the 45 seconds and longer as the directions requests. Any ideas on what to fix ?
Leesmith is offline   Reply With Quote
Old 02-22-2013, 03:27 AM   #2
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
It may not be broken.
When lighting this type of heater the flame is only visible during the lighting process which warms the catalytic material. After you release the lighting button or knob, whatever you have, the flame goes out but heat should continue to radiate from the pad. You may see a slight red glow in the dark, but nothing in normal light.
Hold your hand near it and feel for heat.
When lighting , I usually wave my hand at it to move the flame across the pad more evenly.
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 02-22-2013, 10:22 PM   #3
1984 31' Excella
That would be great if it was really working and I just didn't realize it. I can hear the gas shut off when I slowly turn the knob to low. I'm pretty sure that it isn't lit. I've checked the thermocouple and it is good. My suspect is the valve but I'm not sure if there could be something else I'm not aware of. Thanks for the encouraging idea.
Old 02-22-2013, 11:14 PM   #4
Southwestern , Ohio
Maybe the solution is not to turn the knob to "low". To stay lit, the catalytic wool (or whatever it's called) has to put out enough heat to keep the thermocouple hot. Ours will stay lit on the high setting, but not always on low.
Nuvite-F is offline   Reply With Quote
Old 02-22-2013, 11:24 PM   #5
1984 31' Excella
Great! I'll give that a try. I have to go thru "low" before it turns to high. It usually goes off on low. If I turn it fast enough, maybe it will keep the gas flow going long enough to keep it going. The trailer is in the shop right now so ill try that when I get it back. It's on the shop for the main furnace problems. Thanks.
Old 02-23-2013, 10:17 AM   #6
1988 32' Excella
Robbinsville , New Jersey
What is the problem with the main furnace?
If the furnace is having trouble lighting or staying lit it could be related.
Possibly propane flow restriction or regulator starting to go bad.
Old 02-23-2013, 11:19 AM   #7
1984 31' Excella
It could be connected. We'll find out what the shop says. The main furnace does light and runs for awhile but then shuts off the heat but keeps blowing cold air. Then it may heat up again before the fan turns off. The catalytic heater won't work with nothing else on.
Old 02-23-2013, 12:53 PM   #8
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
The fan will continue to run on the furnace for a while after burner shut down to purge any unwanted gasses. I wintered through one time and the blower never would shut off in cold weather although the burner would cycle on and off.. I finally put an indicator light across the valve to convince myself that it wasn't burning gas all that time
13 Ram 2500 TD
Old 12-30-2015, 01:48 PM   #9
1988 34' Excella
Stanardsville , Virginia
Catalytic Therm X heater
Did you ever get the supplemental Therm X working or did you have to buy a new one? How did you test the thermo coupler on the catalytic heater. Mine won't run without holding the push switch, no matter how long I hold it. As soon as I release the switch the flame stops and the heater cools. It doesn't keep generating heat independent of the flame. The igniter works fine. My main suburban furnace works fine but I would like to use the Therm X catalytic heater when it isn't too cold. Any suggestions?
madpiper is offline   Reply With Quote
