Old 12-09-2014, 03:54 PM   #1
danjoe91's Avatar
1985 32' Excella
Valley Village , California
Images: 16
ThermX 635 heater
I am trying to find out how safe these heaters are. I have never used this, because the pilot will not stay lit. I installed a new furnace in the trailer, which works well enough that this does not seem necessary. As this was an original option on my trailer, I want it to work, but should I repair it or replace it with something safer?
Name:	Airstream ThermX 635 Heater.jpg
danjoe91 is offline   Reply With Quote
Old 12-10-2014, 04:09 PM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
Opinions vary. It's a catalytic heater, and I don't think any catalytic heater is safe for use in an RV.
Old 12-10-2014, 04:50 PM   #3
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
I have one--works fine. I don't believe it is any more dangerous than any other propane appliance. Even a brand-new furnace can malfunction, and leak CO, and therefore, a CO detector is a must.
Its been so long since I've used it, though, I don't recall exactly....but I don't think that the pilot is supposed to stay lit. There is a thermocouple, which keeps the gas valve open, but there is no real combustion going on with these things. just a small amount to launch the chemical reaction that occurs, and then the heat from that reaction warms the thermocouple, which keeps the gas flowing. The reaction is from propane +O2 passed through the catalyst, which yields heat +CO2 +H2O.
Since it consumes O2, you should leave a window or vent cracked.
You probably just need to replace the thermocouple.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 12-12-2014, 09:31 AM   #4
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Curious. I have my reservations, but the ones with externally sourced air for combustion seems to cover that reservation. What else to note? Incomplete combustion? The cat pad does seem to be affected by dust over time.
Old 12-15-2014, 07:37 AM   #5
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Catalytic heaters are radiant heaters - they only radiate heat away from the pad; thus they do not really heat the rest of the trailer. My AS came with one (Olympic), and after a few months of freezing my a$$ off when boondocking, I switched it out for a blue flame heater. The blue flame is a convection type of heater; it draws cold air through vents in the bottom and emits hot air from the vents at the top. This results in a flow of air that heat the whole trailer (but NOT anything behind cabinets - i.e., does not heat plumbing pipes and holding tanks). While they do come with O2 sensors, I always crack open a window as well as the vent on top of the stove and the vent in the shower stall.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Old 12-15-2014, 09:23 AM   #6
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
Originally Posted by blkmagikca View Post
... I switched it out for a blue flame heater.
got a link for this?
Air:291
Wbcci: 3752
'73 Safari 23'
Old 12-16-2014, 07:57 PM   #7
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Take your pick: http://www.amazon.com/s/ref=nb_sb_no...e+flame+heater
I bought a 10,000 btu Procom heater 3 years ago. It heats the entire 32-ft Excella.
VE3JDZ
AIR 12148
Old 12-17-2014, 08:48 AM   #8
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
The Platinum Cat Heater is the one of which I was thinking. Draws exterior air for combustion.
Old 12-17-2014, 09:51 AM   #9
Wise Elder
Jammer's Avatar
2010 30' Classic
I've written elsewhere on the hazards and on alternative heaters to consider. A search will bring up these posts.
The hazards with catalytic heaters are:
- gradually elevated co levels as the pad deteriorates with time and use
- elevated co levels in the event of various mechanical problems, such as partial blockage of the venturi
- oxygen depletion, a problem in its own right and also something that will lead to more co
- accumulation of other toxic products of combustion in the very small living space
There are many alternative heat sources for use while boondocking although they are generally more expensive and more difficult to install since they require outside air. Dickenson/Newport propane furnace, propex heater, etc.
Old 12-17-2014, 09:58 AM   #10
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
ThermX 635 heater
Thanks.
Have you looked at www.ventedcatheater.com?
Regular pad replacement seems reasonable.
Old 01-20-2015, 03:24 PM   #11
Wise Elder
Jammer's Avatar
2010 30' Classic
Availability seems to be an ongoing problem with the ventedcatheater folks.
It is unclear to me from their website whether their product has AGA/CGA approval. I wouldn't install it without one or the other. The approval means there have been independent third-party tests of things like clearance, failure modes, etc. I am skeptical because the design lacks outside air for combustion and with the extremely small fan it is unclear to me how there could be sufficient exhaust airflow under all conditions (e.g. heavy winds ).
There are better alternatives
Old 01-20-2015, 10:23 PM   #12
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Thank you, Jammer. I had the impression you knew more than me. Bookmarked for that day.
Old 01-20-2015, 10:32 PM   #13
New Borockton , Alabama
Images: 21
We used ours for years in our 76. Worked perfect and is next to the door where most of the cold comes in during the evening when you are opening the door letting the dog out, bringing in the BBQ stuff, getting a cold beer, etc. It's not a furnace, its to help the furnace. You can always turn it off before you go to bed. I'd use it.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp Solar, AGM Batteries
www.bestconverter.com
Therm'X model 635 Catalytic heater Leesmith Furnaces, Heaters, Fireplaces & Air Conditioning 8 12-30-2015 12:48 PM
ThermX heater danjoe91 LP Gas, Piping, Tanks & Regulators 2 12-15-2014 06:32 AM
Vulkem 635 or 636? Dano57 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 08-17-2006 10:04 PM
Thermx propane heater jujubee_1 Member Introductions 1 03-20-2006 04:17 PM
