Old 10-17-2008, 06:18 PM   #15
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
So back to my original questions. It doesn't seem like there was a clear answer.
Can this thermostat be adjusted? Do I need to change the original thermostat to improve or stop the furnace short cycling?
Do I have this right:
The NT30 heats up the trailer pretty quick. That is part of the reason for the short cycling. The old smaller btu output heated the trailer slower so the heating cycle was longer.
A second reason for the short cycling is the factory presets on the thermostat and no way to adjust them.
A third reason for the short cycling is a trailer cools fairly quickly because of insulation limitations.
So is switching to an adjustable thermostat my best option to improve the short cycling?
Old 10-17-2008, 11:56 PM   #16
bhayden's Avatar
1978 24' Argosy 24
Woodinville , Washington
Trailers lend to be over BTU'd (is that a W word ) from the start. Larger is not better when it comes to heating (or cooling but that's less of an issue with trailers). If you have way more heat output from the furnace than what's needed to maintain the set point the tstat's not going to fix the problem. A programmable tstat lets you digitally select the temperature swing. Typical values are 1-3 degrees. The tstats have a dampener built in (i.e. they don't instantly react to a change in temperature) but still that's not going to really fix the problem. It's like you're trying to saute with a blow torch. The furnace is just dumping way to much heat into the trailer to maintain a comfortable balance.
Best bet, short of replacing the furnace is to find a point in the trailer where the temperature swings are minimized. That's likely to be down near the floor far away from the furnace. This is a band-aid approach. The other option is to just set up a manual control where you turn on the furnace when you feel cold. Feeling cold may be WAY different that what the temperature at any fixed point in a trailer is. Unfortunately this doesn't work at night unless someone volunteers to stay up and keep watch.
bhayden is offline   Reply With Quote
Old 10-18-2008, 07:40 AM   #17
StingrayL82's Avatar
San Angelo , Texas
Images: 37
Lumatic, I also have the NT-30 and the t-stat that came with it crapped out shortly thereafter...don't waste your money on a new one. I went to Home Depot and bought a cheapo wall mounted t-stat and installed it. Yes, they're supposed to be 24v, but they do work. I've had mine installed for two years now with no problems whatsoever. The temp stays nice and warm, and the NT-30 does NOT cycle so much that it drives you nuts. I'll go over to the garage and take a pic of it to show you.
Edit: Okay, here are the pics. It's a Lux T-Stat; couldn't remember the name before. It's a total K.I.S.S. T-Stat. BTW, the thermometer is working correctly....it's 47* @ 9AM!!!!
Name:	Lux T-Stat 001.JPG
ID:	69727   Click image for larger version
Name:	Lux T-Stat 002.JPG
Frederic
1971 Sovereign International - SOLD
2004 F-350 King Ranch
AIR # 8239
EX-WBCCI # 8371
StingrayL82 is offline   Reply With Quote
Old 10-18-2008, 08:54 AM   #18
Lumatic's Avatar
1993 34' Excella
Images: 16
Thanks Stingray.
You also answered my question about if I need a thermostat specifically for 12v
Marshall
Old 10-18-2008, 10:00 PM   #19
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
24 Volts?
Hi, it's been a few years now since I replaced my thermostat with a new digital model. [about $20.00 or less] The 24 volts basically means it works on a low voltage system versus 120 volts or 240 volts ETC. I don't have a closer picture of it, but I bought the simplest digital thermostat that I could find at Home Depot. And I purposely bought one without the 5 or 7 day program since I don't live in my trailer and everywhere you camp your needs might be differrrent. Click to enlarge picture.
Name:	My Picture CD 429 (Large).jpg
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 12-30-2008, 05:55 PM   #20
Lumatic's Avatar
1993 34' Excella
Images: 16
I got an Atwood thermostat and it solved the short cycling..
Old 12-30-2008, 06:20 PM   #21
rogerdodger's Avatar
Fresno/Clovis , California
Hi Marshall, where did you get it, and how much?
thank you,
Roger
Air# 29488
rogerdodger is offline   Reply With Quote
Old 12-30-2008, 08:34 PM   #22
Lumatic's Avatar
1993 34' Excella
Images: 16
Atwood thermostat
thank you,
I got it from a local RV supply store. It cost less than $20. It's basic but gets the job done.
Old 12-30-2008, 09:07 PM   #23
cameront120's Avatar
1972 25' Tradewind
Is it digital?
North Vancouver, BC
Old 12-31-2008, 06:57 AM   #24
Lumatic's Avatar
1993 34' Excella
Images: 16
Originally Posted by cameront120 View Post
Is it digital?
It has mechanical controls with an anticipator and looks similar to the thermostat in post 17 above
why Two Thermostats? ALANSD Furnaces, Heaters, Fireplaces & Air Conditioning 6 12-09-2006 06:11 AM
