Old 02-15-2016, 06:20 PM   #1
2007 19' International CCD
The Woodlands , Texas
Thermostat upgrade
I replaced my furnace thermostat, Atwood Model HFH-2000 with a Hunter Model 42999B. It's a two wire system so I just connected one wire to W and the other to Rh with the jumper installed from Rh to Rc. When I power the airstream (via In Use switch) after having made the new thermostat connections, the furnace fuse blows. I reinstalled the old Atwood thermostat and all works great (except I rather have a digital). Tried to reinstall the new Hunter blowing the fuse again. Any Ideas how I can get it his new Hunter digital thermostat working?
eberrobw is offline   Reply With Quote
Old 02-15-2016, 09:01 PM   #2
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
The original Atwood thermostats were made to handle the furnace current; your new digital one is probably not. I changed my thermostat and had to add an interposing relay, because it kept burning the contacts in the new stat.
That said, I have no idea why your fuse is blowing, but check for contact where the wires come through the wall.
There's also a toll free number in the manual: http://www.manualguru.com/hunter-fan...-manual/page-2
Old 02-16-2016, 08:01 AM   #3
Thanks for the reply. I wired the new 42999b per the 2-wire heat only diagram on page 2 of the document you provided. I'm wondering why I really need (remove) the supplied jumper between Rh and Rc and if I changed the two wire connections to W and Rh? Anyway, I'll call Atwood. Thanks for your help.
Old 02-16-2016, 08:27 AM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
Reinstall the original thermostat and buy a digital thermometer. Would be better than having to introducing a relay system to allow the new stat to work.
Other than visual display there is nothing the new stat will have to offer.
2004 Excursion 4x4
Old 02-16-2016, 10:02 AM   #5
Images: 59
Really. I "downgraded" from digitial to analog when the digital failed and I couldn't repair in the field.
Old 02-16-2016, 10:36 AM   #6
Thermostat Replacement
Thanks all for your help. It's just sort of a challenge for me to figure out how to get this Hunter digital thermostat working. Still messing with it, I'll let you know how I make out.
Old 02-16-2016, 01:09 PM   #7
KYAirstream's Avatar
Northeastern , Kentucky
Thermostat upgrade
I installed the same thermostat and didn't have any issues. I just connected the two wires and did not install a jumper. That said, a jumper may have already been in place. I can check the next time I'm at my camper. Also, I'm not sure what difference it would make since this is essentially just a switch supplying juice to the furnace, but my furnace is a Suburban.
KYAirstream is offline   Reply With Quote
Old 02-16-2016, 01:46 PM   #8
Another thought is that maybe there is something wrong with the thermostat itself, thereby causing your fuse to blow.
Thermostat replacement jcanavera 2000 - 2004 Safari 7 07-26-2017 08:58 AM
'96 Excella thermostat replacement/upgrade bobjackson Furnaces, Heaters, Fireplaces & Air Conditioning 0 12-28-2011 04:12 PM
Digital Thermostat jcanavera Furnaces, Heaters, Fireplaces & Air Conditioning 27 12-28-2009 03:20 PM
04 furnace thermostat upgrade kstampa Furnaces, Heaters, Fireplaces & Air Conditioning 3 12-24-2009 06:51 AM
installing the thermostat upgrade on Carrier shermantic Furnaces, Heaters, Fireplaces & Air Conditioning 0 08-03-2009 09:57 AM
