Old 10-14-2006, 05:00 PM   #1
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Thermostat Replacement
my Suburban furnace thermostat was corroded. I replaced it with the round Honeywell style, set up for 2 wire connection. I wired it using the r and g terminals , and it seems to be ok, but I am checking if anyone else can confirmn this. The furnace comes on then goes off, but it is still quite warm here so I can't tell if its acting right or what.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 10-14-2006, 05:23 PM   #2
Images: 59
I guess I wouldn't use a round Honeywell style thermostat. They operate with a mercury switch. They're fine in a house, where everything is nice and level and doesn't move.
In a RV, where the attitude can change just by walking from front to back, I would either use a digital thermostat, or an old non-mercury thermostat.
I just replaced the furnace in my '59 and have an original thermostat I can send you. Send me your address and I will shoot it out to you.
In the meantime, I think you can safely use the Honeywell, it just might act a little schizoid.
Old 10-14-2006, 05:43 PM   #3
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
Greetings Mark,
WHat did you replace yours with? I'm looking for ideas.
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
Old 10-14-2006, 05:53 PM   #4
Images: 59
Ken,
I put in a Penguin AC with the "Comfort Control Center". It's a digital thermostat that controls the AC, heat strip in the AC, and any furnace you want to hook up to it. It can also do zone control, but in a 24' Tradewind, I think I just have one zone.
The furnace is a Suburban SF model.
Old 10-14-2006, 05:54 PM   #5
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
sheesh, did n0t think about the mercury....at least it was only 20 bucks.On sale....Walmart.
AIR #005
retired!
Old 10-14-2006, 05:59 PM   #6
Alumaholic's Avatar
1966 24' Tradewind
Images: 33
Ken,
In the AC mode, does the Penguin with CCC have a continuosly running fan, or will the fan cycle on and off as the CCC calls for more cool?
Ken L
1966 Tradewind 24
Old 10-14-2006, 06:07 PM   #7
1976 25' Caravanner
Campton , New Hampshire
Some home style thermostats cannot be shut off completely , they go down to about 50 deg and that's it . In a trailer there may be times you want the furnace off and still have propane on to run the frig or stove . Not sure of the one you have .
ticki2 is offline   Reply With Quote
Old 10-14-2006, 07:03 PM   #8
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I just bought an electronic unit for my house today from Home Depot, cost $28, heat and cool, and it is programmable.
Old 10-14-2006, 07:05 PM   #9
Images: 59
I believe it shuts off; I know the in heat strip mode the fan shuts off once temperature is achieved. I've only run the AC once since I put it in. I'll check it again tomorrow and post back again if the fan doesn't shut off.
The CCC also has a 'Fan Only' mode with three speeds.
Old 10-14-2006, 07:08 PM   #10
Images: 59
I use a mercury thermostat in my garage, where I keep the heat around 45 deg. Just mount the thermostat at about a 10 deg. angle out of plumb, and remember to subtract 20 degrees from the dial setting.
Old 10-14-2006, 07:39 PM   #11
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
this Honeywell does have an on and off switch also.
AIR #005
retired!
Thermostat replacement jcanavera 2001 Safari 7 07-26-2017 08:58 AM
Water heater replacement Craig Water Heaters, Filters & Pumps 36 12-18-2014 09:13 AM
Water inlet key replacement Road Ruler Fresh Water Systems 7 09-03-2002 09:07 PM
Accordian Door Replacement Tamara Upholstery, Blinds, Walls & Interior Finishes 2 06-17-2002 12:08 PM
Converting the old heater to a thermostat? 61BambiCanada Furnaces, Heaters, Fireplaces & Air Conditioning 1 05-22-2002 06:09 AM
