Old 10-22-2009, 10:35 PM   #1
1973 25' Tradewind
Abbotsford , British Columbia
Thermostat repair or bulb replace
The thermostat on my 1973 Tradewind seems to prefer approximately -30 as the daily outside temperature. Is there a way to either recalibrate the thermometer or replace the bulb?
Thank you.
Brian
bridor15 is offline   Reply With Quote
Old 10-23-2009, 03:16 AM   #2
Thank you.
Brian
Brian.
Replace the complete thermostat, as the failure rate of the original, is about 99.9 percent.
Old 10-23-2009, 06:50 AM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Thank you.
Brian
It sounds like the unit is DOA. You could probably get a more modern, more reliable thermometer to go in the hole. I put an indoor-only thermometer in the hole where ours was, and re-used the cover and trim. That is, if you are talkiing about the thermometer and not the thermostat, you called it both things in your post.
Old 10-23-2009, 09:46 AM   #4
1973 25' Tradewind
Thank you. It is the thermometer and not the thermostat. Can I purchase a replacement unit?
Brian
Old 10-23-2009, 12:06 PM   #5
Brian
Many stores cary household type thermometers, with a bulb.
That part was not an Airstream specific part.
Same is true with a matching clock.
Toilet: Repair or Replace bilby05 Sinks, Showers & Toilets 17 01-12-2012 07:02 PM
Refrigerator repair or replace? DGBMLB Refrigerators 18 09-11-2011 10:49 PM
Tank repair or replace? FreshAir Waste Systems, Tanks & Totes 13 10-10-2006 11:38 PM
repair or replace a/c? hively Furnaces, Heaters, Fireplaces & Air Conditioning 12 07-19-2004 11:37 PM
Sink...Repair or Replace?? COArgosy78 Sinks, Showers & Toilets 17 08-05-2003 03:28 PM
