Old 11-28-2015, 11:45 AM   #1
Levelland , Texas
Thermostat problems
I have a 2014 Airstream with two Dometic airconditioners. Zone 1 works good but zone 2 shows inside temp at 32 degrees. The ac will not cool and the furnace will not shut off. No help from Airstream or Dometic since I am the second owner. All help would be appreciated.
Troy Tyson is offline   Reply With Quote
Old 11-28-2015, 01:01 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Are you saying the inside temperature of the trailer is actually 32 degrees. If so I would assume the heater would not shut off and clearly the AC would not come on.
More details please
2004 Excursion 4x4
Old 11-28-2015, 02:41 PM   #3
Levelland , Texas
It may be 85 degrees inside the trailer and the thermostat shows 32 degrees
Old 11-28-2015, 05:07 PM   #4
HowieE's Avatar
Images: 12
Sounds like a dead thermostat. First think I would do is swap them and see if he problem moves with the change. If s get new one.
If the problem does not move it is in the unit. The AC may not be supplying correct voltage to the thermostat
2004 Excursion 4x4
Old 11-28-2015, 07:45 PM   #5
richinny's Avatar
2011 34' Classic
common problem if you have a high humidity condition. the line that transmits the inside temp gets wet and send an incorrect temp until it dries out. if you remove the inside cowl you can see the two connectors that look like phone lines. there are threads here about this issue.
Ricky
Penguin Heat Pump / Thermostat Problems Bob Thompson Furnaces, Heaters, Fireplaces & Air Conditioning 6 08-04-2010 07:06 PM
JC With Problems, Same Problems Goin Home ncbambi 2008 Safari SE 3 06-23-2009 09:44 PM
Update on Problems Problems pjude General Motorhome Topics 4 09-04-2007 06:02 AM
Problems Problems Problems pjude General Motorhome Topics 6 09-03-2007 07:25 AM
Thermostat or ?????? problems Kistler Furnaces, Heaters, Fireplaces & Air Conditioning 1 09-13-2006 09:18 PM
