Old 09-13-2006, 08:59 PM   #1
Kistler's Avatar
2002 25' Classic
Oro Valley , Arizona
Thermostat or ?????? problems
Our heat pump quit working suddenly...had it on "auto" fan and it began to shut the fan off but left something buzzing.
Then the air conditioner would not work....fan runs but the compressor will not go on.
The furnace works!
Any ideas on where the problem is or the problems are? Do I just need a new thermostat? The trailer is only 4.
Kistler & Brenda
2002 Classic 25'
2003 Expedition EB 5.4L, AWD, AdvanceTrac Class IV hitch pkg. Reese dual cam/Prodigy
Kistler is offline   Reply With Quote
Old 09-13-2006, 09:18 PM   #2
2005 19' Safari
Duluth , Minnesota
Bummer
Were you hooked up to a power supply that was 30amp? I don't profess to have much knowledge in this area. If your supply was either not up to the task or subject to significant surge fluctuations, you may have damaged your unit, hence the noise after shut-down... I'm afraid I'd be talking to my local repair shop over this one! Sorry I'm not of more help.
skykingpilot is offline   Reply With Quote
Thermostat replacement jcanavera 2001 Safari 7 07-26-2017 08:58 AM
Digital Thermostat jcanavera Furnaces, Heaters, Fireplaces & Air Conditioning 27 12-28-2009 03:20 PM
Oven Thermostat PeterH-Airstreamer Stoves, Ovens & Microwaves 33 02-20-2003 09:39 AM
Fridge Cooling Problems 68International Refrigerators 6 07-10-2002 03:53 PM
Converting the old heater to a thermostat? 61BambiCanada Furnaces, Heaters, Fireplaces & Air Conditioning 1 05-22-2002 06:09 AM
