Old 11-16-2009, 12:44 PM   #1
1977 27' Overlander
Beatty , Nevada
Thermostat On/Off
77 Overlander,
For both the furnace and the A/C my service manual references an off/on switch on the thermostat. The thermostat is labeled suburban. A/C appears to be an Armstrong and I'm assuming the furnace is a Suburban as it appears to be original.
TIA
77Overlander is offline   Reply With Quote
Old 11-16-2009, 03:34 PM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
On my 73 there was a small toggle switch on the OEM furnace thermostat.There was a separate thermostat for the AC.
Old 11-16-2009, 09:12 PM   #3
1977 27' Overlander
Beatty , Nevada
I saw another reference to another thermostat for the A/C but can't find it. The 'stat in my 5th wheel has switch for furnace on/off and fan speeds so I'm quite puzzled.
Old 11-16-2009, 10:19 PM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
If it is the original Armstrong a/c, the thermostat for it should be on the streetside, usually on the wall near the fridge. There is an on/off switch, along with fan speed settings on the base of the a/c unit itself.
If it is a replacement a/c chances are good there is no longer a separate thermostat for it.
Old 11-18-2009, 05:31 PM   #5
1977 27' Overlander
Beatty , Nevada
Terry,
Thanks - the overhead switch on the fan is 3 speeds plus on/off. So if there's no thermostat what the dickens is controlling temperature - just the fan speed?
Mike
A/C Thermostat Devoman Furnaces, Heaters, Fireplaces & Air Conditioning 7 06-01-2014 11:42 PM
Digital Thermostat jcanavera Furnaces, Heaters, Fireplaces & Air Conditioning 27 12-28-2009 03:20 PM
Thermostat burning out ayresdream Furnaces, Heaters, Fireplaces & Air Conditioning 8 01-17-2007 08:05 PM
Thermostat on fridge. ssww Refrigerators 7 11-20-2005 07:03 PM
Furnace Thermostat neil.ervin Furnaces, Heaters, Fireplaces & Air Conditioning 15 11-27-2004 05:45 PM
