Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 12-11-2002, 12:13 PM   #1
John
Profile:
Thermostat- heat strip
According to my Duo-Therm manual, the ac thermostat does not control the optional heat-strip. Does the heat-strip have an internal thermostat or does it just continue to heat?
I turned it on this morning around 3:00am and by 5:30am, it was too warm inside the trailer.
Many Thanks, John
p.s. The ceramic heater that I've been using failed last night, so I had to use the heat-strip as a back-up. I did replace the ceramic heater today and will use this in the future, as it has a thermostat.
John is offline   Reply With Quote
Old 12-11-2002, 01:47 PM   #2
jcanavera
jcanavera's Avatar
Profile:  2004 30' Classic Slideout
Fenton , Missouri
Images: 143
John,
The Duo-Therm Penguin on my Safari does not have a thermostat on the heat strip. You turn it on and when you get warm you turn it off. I didn't know this initially. Sort of a disappointment.
Jack
Jack Canavera
STL Mo.
AIR #56
'04 Classic 30' S.O.
'03 GMC Savana 2500
'08 Vespa GTS 250
Old 12-11-2002, 02:35 PM   #3
John
Profile:
Jack,
It sure is disappointing, since it seems to be a simple thing to have available. I woke up almost in a sweat!!!
John
Old 12-11-2002, 03:09 PM   #4
Pahaska
Pahaska's Avatar
Profile:  2005 28' Classic
Austin (Hays County) , Texas
Images: 12
The heat strip is good for one thing
And that's taking the early morning chill off.
I use two ceramic heaters, a Pelonis with a thermostatic variable speed fan and variable heating element, and a cheapie SOB that I paid about $15 for years ago. The cheapie varies only from 800 - 1600 watts. I put the cheapie at the lowest setting in the bathroom with the door left open. Then, I set the Pelonis near the entry door set at about 65 degrees.
With the temperature right at freezing, the Pelonis only revs up once in a while. Meanwhile, the bathroom stays cozy warm.
The Pelonis is a great heater with tip over and overheat safety switches that the cheap one doesn't have.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2004 Silverado 2500HD Duramax/Allison
WBCCI Region 9 Webmaster, #9632
Old 12-11-2002, 03:35 PM   #5
John
Profile:
John,
We talked about this a couple of weeks ago. You have the 5 disc ceramic furnace ($74 @HD). I have the ceramic heater 1500W w/two heat settings, thermostat control, safety tip over switch, overheat thermal protection and inlet air overheat protection ($17 @ HD). The fan motor died and I replaced it today. It works great, I just got a lemon motor.
John
Old 12-12-2002, 04:21 PM   #6
James Schmidt
Profile:  1993 29' Excella
Jonesboro , Louisiana
The heat strip in my Pinguin duotherm has a thermostat that cycles the heat. This is the same T stat that controls the A/C when in the cooling mode. There is a switch on the control that switches from heat to cooling. The wall T stat in my unit controls only the propane heat. The controls for the heat/Air are an intergral part of the unit mounted in the ceiling.
James Schmidt
29 ft Excello 1000
97 Expedition/Hensley Hitch/
McKesh mirrors
James Schmidt is offline   Reply With Quote
Old 12-12-2002, 04:27 PM   #7
John
Profile:
are you sure
I too thought the a/c thermostat controlled the heat-strip, but I found out differently in the manual.
John
Old 12-12-2002, 04:32 PM   #8
jcanavera
jcanavera's Avatar
Fenton , Missouri
Images: 143
There are Penguin units that have heat pumps. Those units have thermostatic control of the heat. James, maybe you really have a heat pump unit rather than the heat strip?
Jack
Jack Canavera
STL Mo.
AIR #56
'03 GMC Savana 2500
'08 Vespa GTS 250
Old 12-12-2002, 04:33 PM   #9
James Schmidt
John,
My unit is a 93 model and I have used it extensively to heat on the "just chilly" mornings. It actually does cycle the heat. I can't imagine why yours does not do so.
James
James Schmidt
29 ft Excello 1000
McKesh mirrors
Old 12-12-2002, 04:35 PM   #10
James Schmidt
Jack,
I wish I did have a heatpump! The dealer had my unit apart before I bought it--maybe he made some modifications. I just thought this was normal. It certainly should be.
James
James Schmidt
29 ft Excello 1000
McKesh mirrors
Old 12-12-2002, 05:35 PM   #11
jcanavera
jcanavera's Avatar
Fenton , Missouri
Images: 143
We probably are dealing with the situation where its cheaper to build without a thermostatic control for the heat strip. This is probably the case of newer isn't better.
Jack
Jack Canavera
STL Mo.
AIR #56
'03 GMC Savana 2500
'08 Vespa GTS 250
Old 12-12-2002, 05:56 PM   #12
John
Profile:
you're right
I have a newer a/c and my older unit had a slide switch thermostat which did cycle through the heat mode. I completely forgot about this, that's why I check the manual to begin with.
John
Old 12-12-2002, 06:16 PM   #13
Gordon Watt
Gordon Watt's Avatar
Profile:
Heat Strip
My heater combined with the A/C is on the thermostat.
My unit is 1979. I think it's original.
The furnace packed it in one night when the out side temperature was - 10 C. The heater in the A/C kept the trailer nice and toasty.
Gordon Watt is offline   Reply With Quote
Thermocouple and Thermostat....HIGHWAY ROBBERY!! Alan and Mardel Water Heaters, Filters & Pumps 2 12-23-2003 03:41 PM
Refer heat / venting JaceBeck 1999 Safari 3 08-21-2003 09:40 PM
Heat protection ALANSD Airstream Motorhome Forums 14 11-03-2002 03:55 PM
Heat Riser ALANSD Airstream Motorhome Forums 7 09-11-2002 04:38 PM
HOT Topic for the summer-Air conditioners-Best/worst? thenewkid64 Furnaces, Heaters, Fireplaces & Air Conditioning 4 07-03-2002 05:55 AM
test
