Old 03-20-2010, 04:32 AM   #1
2005 25' International CCD
Kent , Washington
Thermostat Gas Heater - Digital
For my 25' International 2005 with gas heater and mechanical thermosat I am looking into replace and for more accurate setting I prefer digital thermostat.
Do you recomend if there is any digital replacemnt thermostate to purchase specific for my model airstream.
Donk is offline   Reply With Quote
Old 03-20-2010, 04:48 AM   #2
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
I would think any of the digital thermostats from your local hardware store would work. If you are just running your furnace look for one which is furnace only. If you need to control both the furnace and the A/C, those are also available. The only one I think would be hard to find would be Furnace/AC/Heat Pump.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Digital Thermostat jcanavera Furnaces, Heaters, Fireplaces & Air Conditioning 27 12-28-2009 03:20 PM
Water heater thermostat does not shut off gas to burner davelance01 Water Heaters, Filters & Pumps 2 06-12-2009 09:55 AM
Digital Thermostat grannyred Furnaces, Heaters, Fireplaces & Air Conditioning 8 01-18-2006 08:11 AM
Digital wall thermostat for A/C and furnace nickcrowhurst Furnaces, Heaters, Fireplaces & Air Conditioning 2 12-21-2004 08:03 AM
water heater thermostat mgordon Water Heaters, Filters & Pumps 2 07-07-2003 07:16 AM
