Old 04-15-2014, 06:41 AM   #1
terrencecolp's Avatar
1976 25' Tradewind
Tulsa , Oklahoma
Thermostat for Armstrong A/C
Does anyone know if a thermostat could be installed on an air conditioner which hand not been assembled with one? I own a 1976 Armstrong unit with three fan speeds. In order to keep my trailer at a comfortable temperature, I have to be the human thermostat. Too hot? Jump up and switch it up a speed. Cold? Get up and, well you get the idea.
terrencecolp is offline   Reply With Quote
Old 04-15-2014, 06:49 AM   #2
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
Your A/C should have another knob for the thermostat control. All the fan speed does is change air flow speed. A picture of your controls would be helpful
I have two Armstrongs and both have thermostats. It is necessary to keep the compressor from freezing up.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
Old 04-15-2014, 12:42 PM   #3
Wise Elder
Jammer's Avatar
2010 30' Classic
There should be one. If not, it was probably removed by a former owner, and can be added again. There are universal replacement parts available that should work.
Old 04-17-2014, 05:36 AM   #4
1976 25' Tradewind
Tulsa , Oklahoma
Now of course I've got the separate wall thermostat for my Suburban furnace, but it has no cool switch. It is very odd, all my a/c really is a window unit with the output duct running down instead of straight, and I have never seen a window unit without a thermostat. I am at a loss why they designed it that way. The compressor never cycles. There certainly isn't a panel switch, maybe they figured with all the heat loss through windows full speed would be all anyone would use.
Old 04-21-2014, 05:59 AM   #5
1976 25' Tradewind
Tulsa , Oklahoma
I removed the inside cover and found a schematic that implied wiring to a thermostat. It also had three wires that had been cut and taped off.
Old 04-21-2014, 02:08 PM   #6
4RXLA's Avatar
1977 31' Excella 500
West Sacramento , California
Images: 33
There should be a separate thermostat located somewhere in the living room area that controls the A/C compressor. Fan must still be turned off manually but the compressor and heat strip will come on and off based on that thermostat. Look for a patched hole somewhere on your roadside living room area close to the kitchen.
4RXLA is offline   Reply With Quote
Old 04-21-2014, 02:57 PM   #7
bwoodtx's Avatar
1997 30' Excella
San Antonio , Texas
pictures???
Bruce
Anyone got a thermostat for an Armstrong AC Lumatic Furnaces, Heaters, Fireplaces & Air Conditioning 12 08-05-2013 09:14 PM
Wiring thermostat to Armstrong Bay Breeze A/C Ddanielgriff Furnaces, Heaters, Fireplaces & Air Conditioning 2 08-03-2013 08:30 AM
HELP, On Armstrong AC Thermostat mburgess1431 Furnaces, Heaters, Fireplaces & Air Conditioning 7 08-27-2012 01:07 AM
Armstrong Thermostat Beginner Furnaces, Heaters, Fireplaces & Air Conditioning 3 04-07-2010 07:49 AM
Thermostat Lost 1975 Armstrong Collusion Furnaces, Heaters, Fireplaces & Air Conditioning 5 05-28-2007 05:31 PM
