04-15-2014, 06:41 AM
1976 25' Tradewind
Tulsa
, Oklahoma
Thermostat for Armstrong A/C
Does anyone know if a thermostat could be installed on an air conditioner which hand not been assembled with one? I own a 1976 Armstrong unit with three fan speeds. In order to keep my trailer at a comfortable temperature, I have to be the human thermostat. Too hot? Jump up and switch it up a speed. Cold? Get up and, well you get the idea.
04-15-2014, 06:49 AM
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio
Your A/C should have another knob for the thermostat control. All the fan speed does is change air flow speed. A picture of your controls would be helpful
I have two Armstrongs and both have thermostats. It is necessary to keep the compressor from freezing up.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a great dog.
04-15-2014, 12:42 PM
Wise Elder
2010 30' Classic
South of the river
There should be one. If not, it was probably removed by a former owner, and can be added again. There are universal replacement parts available that should work.
04-17-2014, 05:36 AM
1976 25' Tradewind
Tulsa
, Oklahoma
Now of course I've got the separate wall thermostat for my Suburban furnace, but it has no cool switch. It is very odd, all my a/c really is a window unit with the output duct running down instead of straight, and I have never seen a window unit without a thermostat. I am at a loss why they designed it that way. The compressor never cycles. There certainly isn't a panel switch, maybe they figured with all the heat loss through windows full speed would be all anyone would use.
04-21-2014, 05:59 AM
1976 25' Tradewind
Tulsa
, Oklahoma
I removed the inside cover and found a schematic that implied wiring to a thermostat. It also had three wires that had been cut and taped off.
04-21-2014, 02:08 PM
1977 31' Excella 500
West Sacramento
There should be a separate thermostat located somewhere in the living room area that controls the A/C compressor. Fan must still be turned off manually but the compressor and heat strip will come on and off based on that thermostat. Look for a patched hole somewhere on your roadside living room area close to the kitchen.
04-21-2014, 02:57 PM
1997 30' Excella
San Antonio
pictures???
Bruce
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Anyone got a thermostat for an Armstrong AC
Lumatic |
Furnaces, Heaters, Fireplaces & Air Conditioning |
12 |
08-05-2013 09:14 PM |
Wiring thermostat to Armstrong Bay Breeze A/C
Ddanielgriff |
2 |
08-03-2013 08:30 AM |
HELP, On Armstrong AC Thermostat
mburgess1431 |
7 |
08-27-2012 01:07 AM |
Armstrong Thermostat
Beginner |
3 |
04-07-2010 07:49 AM |
Thermostat Lost 1975 Armstrong
Collusion |
5 |
05-28-2007 05:31 PM |
