Old 08-18-2011, 10:58 PM   #1
Oakland , California
Thermostat dead?
hello everyone,
i'm having an issue with no display coming up on my 4 button duo-therm thermostat in my 96 excella. is the thermostat dead or could a fuse be blown? where would i check fuses?
TIA!
vegburner is offline   Reply With Quote
Old 08-19-2011, 05:46 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
The thermostat gets its power directly from a transformer in the a/c. So, check first to make sure the a/c is getting power, then check the telephone wire plug at the thermostat to make sure it's getting power and ground. It could be a tripped breaker or loose connector on the plug in the thermostat or a/c unit.
Old 08-19-2011, 09:38 AM   #3
thanks for the reply - how would i check voltage at the telephone wire plug?
Old 01-27-2012, 01:21 PM   #4
Bob Thompson's Avatar
Corpus Christi , Texas
Images: 67
Did you ever get your thermostat working properly? My '97 Excella thermostat works, but sometimes the buttons get balky then they suddenly start working jumping the choice down two or three items on the display. I'm trying to determine if someone has the answer whether to replace or have a tech rebuild it. There's a guy on Ebay offering that service.
So Long!
Bob Thompson is offline   Reply With Quote
Old 01-27-2012, 03:09 PM   #5
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
I found this on another site.
First remove your comfort control from the wall. Remove cover to expose ckt board and plunge switches. (FOUR BUTTONS). Spray all four buttons with electronic contact cleaner. Work buttons. Do this three to four times. Spray dry with caned air.(DUST OFF by Falcon) Any one can do this. It works......
Garry
Old 01-30-2012, 10:51 AM   #6
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Bob,
I had the exact same problem on our '99 Excella. They don't make our model anymore, and a refit up to the next model involved a lot of replacement parts for the A/C unit as well. Over $200 as I recall. I love the post by garry telling us to spray the contacts and dry it out. I'm going to try that for sure. - GH
Linda Heuer. President Shen. Valley Unit
Greg Heuer, 2nd VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Old 02-11-2012, 06:34 PM   #7
danlehosky's Avatar
2012 25' FB Flying Cloud
Gig Harbor , Washington
We had this happen to our new FC. We took it to the dealer for this and other service and he said some water hadpooled at the connection area of the roof and shorted everything out. Got it back yesterday and all seems well.
danlehosky is offline   Reply With Quote
Old 02-11-2012, 06:50 PM   #8
Images: 67
We found a guy on Ebay that rebuilds/refurbishes them for $110 exchange, so we went that route. It took about 3 days to get the refurbished unit in and installed. Worked perfectly even if a little pricey.
So Long!
[Q] MC16c thermostat stuck flashgrbiv Refrigerators 4 05-21-2011 09:48 AM
Suburban furnace thermostat install? adwriter73 Furnaces, Heaters, Fireplaces & Air Conditioning 6 04-04-2011 02:05 PM
where does the 24 volts come from to thermostat 386kustoms Furnaces, Heaters, Fireplaces & Air Conditioning 20 02-06-2011 05:11 PM
thermostat prewire on 04 28' Intl? FullTimin2HI Furnaces, Heaters, Fireplaces & Air Conditioning 4 02-02-2011 10:47 AM
