Old 03-10-2016, 09:55 PM   #1
2015 22' FB Sport
Olatje , Kansas
Thermostat and heat
Feeling quite stupid but here it is.. Trying to figure out if the thermostat is broken on our 22fb.
The manual for the furnace system isn't in our bundle of docs we were given when we bought the camper.
When the dial is on optional heat, it runs regardless of where the thermostat is set. Camper got up to 77 and I shut it down.
Moved the dial to the lowest grey fan slot and bump the thermostat up till it clicked then went a little further.. No heat.
So the only time I seem to get heat is when I'm running on optional heat and even when I mess with the thermostat it doesn't seem to do anything..
Don't want to freeze but also not interested in melting.. What the heck am I missing?
joekr is offline   Reply With Quote
Old 03-10-2016, 10:26 PM   #2
2015 22' FB Sport
Olatje , Kansas
So the on/switch was stuck but it's still not cycling.. Even in the on position, the heat only runs when it's set to optional heat..
Old 03-10-2016, 10:40 PM   #3
2015 22' FB Sport
Olatje , Kansas
Figured it out. I think I drove too long today!
Thermostat for Heat Pump-switch problem A W Warn Furnaces, Heaters, Fireplaces & Air Conditioning 14 01-15-2014 08:29 PM
Dometic Briskair thermostat not working on heat perryg114 Furnaces, Heaters, Fireplaces & Air Conditioning 14 10-23-2012 07:07 PM
Thermostat-Dual Heat Pumps carlose Electronics & Connectivity 0 10-09-2011 04:02 PM
Penguin Heat Pump / Thermostat Problems Bob Thompson Furnaces, Heaters, Fireplaces & Air Conditioning 6 08-04-2010 07:06 PM
Thermostat- heat strip John Furnaces, Heaters, Fireplaces & Air Conditioning 12 12-12-2002 05:16 PM
