Old 01-26-2009, 09:12 PM   #1
j_c_c's Avatar
1969 31' Sovereign
Los Angeles , California
thermostat/AC wiring diagram?
Howdy Folks!
Got a 1969 Sovereign 31' that has a seperate thermostat for the AC. It was acting funky so I took off the thermostat cover and such and found 3 of the 4 wires just floating about in the casing area inside.
The thermostat (honeywell) case and cover is kinda busted anyway so I plan to replace it (vintage if possible). It has a "off-cool" switch and a "high-low" switch for the fan.
So.... I looked in my manual to figure out what wire will go where, but the manual doesn't go into that much detail. Anyone have any guesses? I'm pretty savvy electrically so I can measure this and that if it helps. One cables is red, the rest are more of less "dark" with age... The red one was the only one connected with a screw inside.
Not sure what brand AC, the trailer is pretty stock so possibly the original installed one? Any easy way to tell otherwise?
Thanks, per usual!
- jc
j_c_c is offline   Reply With Quote
Old 01-28-2009, 12:19 PM   #2
1968 22' Safari
Baton Rouge , Louisiana
I'm not sure if this is the correct diagram, but this came form my 68 safari. Hope it helps.
truc_05 is offline   Reply With Quote
Old 12-03-2009, 07:29 AM   #3
santa clara , California
Hello JC, did you ever figure out the wiring for your thermostat? I just purchased a 75 safari that has four wire coming out if the wall where the thermostat used to be. Excuse my ignorance, but i assume two are forthe A/C and the other two for the furnance. Any idea which are which?
s_zamora is offline   Reply With Quote
thermostat a/c wiring
Aircon and heater thermostat wiring ianrjam Furnaces, Heaters, Fireplaces & Air Conditioning 2 07-04-2007 10:48 AM
Anyone have a Wiring Diagram? Chopper Electrical - Systems, Generators, Batteries & Solar 14 09-22-2006 09:49 AM
Wiring diagram raebaker06 Electrical - Systems, Generators, Batteries & Solar 0 08-29-2004 11:02 AM
Wiring Diagram please Drifter Electrical - Systems, Generators, Batteries & Solar 1 06-04-2004 06:21 PM
Thermostat Wiring Navigator Furnaces, Heaters, Fireplaces & Air Conditioning 3 12-12-2003 09:36 PM
