Old 04-02-2010, 04:59 PM   #1
Send a message via Yahoo to dhe9
thermostat ?
hello,
furnace was working fine and then i went to turn it on last night at the thermostat and nothing (?). i have propane to my stove so i assume there is propane at the furnace. i checked the fuses and all seemed fine. just turned the thermostat on and moved the lever at the bottom and nothing.
normally the blower will come on and then the igniter clicks and i had heat, now nothing and this is while hooked to shore power so i know i have juice. any ideas?
thanks
david
socal
'03 19' bambi
2011 CTD DIESEL
SEMPER FI
RETIRED USMC
dhe9 is offline   Reply With Quote
Old 04-02-2010, 05:04 PM   #2
Silver Mist
LI Pets's Avatar
Riverhead , New York
try taking it off and cross the wires
Old 04-02-2010, 05:08 PM   #3
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Try this: Turn the thermostat off. Take the interior vent cover off where the hot air comes into the Bambi from your furnace. There should be a "reset" switch there. Push the switch to "reset"... Try starting the furnace again from the thermostat. Sometimes when the ignition fails the furnace will automatically shut down and needs to be manually reset.
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
A/C Thermostat Devoman Furnaces, Heaters, Fireplaces & Air Conditioning 7 06-01-2014 11:42 PM
Thermostat On/Off 77Overlander Furnaces, Heaters, Fireplaces & Air Conditioning 4 11-18-2009 05:31 PM
Duotherm thermostat crispyboy Furnaces, Heaters, Fireplaces & Air Conditioning 5 10-31-2008 07:50 AM
Using remote thermostat for a/c? overlander63 Furnaces, Heaters, Fireplaces & Air Conditioning 6 03-23-2008 08:38 PM
Thermostat on fridge. ssww Refrigerators 7 11-20-2005 07:03 PM
