Old 06-03-2013, 05:07 PM   #1
Mikec1231's Avatar
2012 27' FB International
Ormond Beach , Florida
There must be a way to run only the LP Furnace...
Some how in the new vehicle prep, I missed how to control just the LP furnace without running the Dometic heat pump. (The heat pump is so noisy, it would be nice to just run the furnace for 10 minutes to take the evening chill off the unit). My AS is a 2012 27FB.
The vehicle instruction book does not seem to cover how to control it. Maybe it is the Zone 2 on the thremostat??
Thanks for your help.
Mike
Mikec1231 is offline   Reply With Quote
Old 06-03-2013, 05:48 PM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Select "FURN" in the mode. If "FURN" is not shown as an option, try switching from zone 1 to zone 2.
Old 06-03-2013, 06:40 PM   #3
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
You definitely should be able to run the furnace by itself. In ours the thermostat mode can be set to "furnace" or "heat pump" (or "cool" of course). They don't run simultaneously. (We only have 1 zone in the Bambi which may or may not be a consideration for you)...
TB & Greg and Abbey Schnauzer
#3954
