Old 06-08-2009, 12:13 PM   #15
Diesel1's Avatar
1967 24' Tradewind
Wickenburg , Arizona
My a/c fan on the 67 is differant than yours but.... I took my motor clear off washed the whole thing in auto parts washer, let it soak in the solvent a bit then blew dry and disassembled to lube the non lubable bushing. So far so good. Adios, John
Diesel1 is offline   Reply With Quote
Old 06-08-2009, 12:48 PM   #16
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
Originally Posted by redhawkerII View Post
The wheel (fan) inside the Ac in our unit tends to not want to start turning when we set the thermostat to ON...so we end up having to remove the cover and reach up inside and give it a push or pull rather to get it going
It might now be the same issue, but on my 1976 Sovereign the old Armstrong AC when we first got would turn on but no air, or very little air came out of the vent. After doing about what you have done already I discovered that the squirrel cage blower that you can access from the inside was just spinning on the motor shaft. The allen screw that held it in place had loosened. After tightening this the blower and AC worked fine for a few more years. I replaced it with a new Carrier 15,000 btu unit.
Don
adonh is offline   Reply With Quote
Old 06-08-2009, 02:20 PM   #17
StingrayL82's Avatar
San Angelo , Texas
Images: 37
I guess we're one of the lucky ones....our Armstrong is still cranking out ice-cold air. We've had to replace two electrical parts, one in 2006 and one in 2007, but other than that it's been very dependable, knock on wood.
Frederic
1971 Sovereign International - SOLD
2004 F-350 King Ranch
AIR # 8239
EX-WBCCI # 8371
StingrayL82 is offline   Reply With Quote
Old 06-08-2009, 08:30 PM   #18
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
Well at last we think this will work...An AC friend downtown gave me a bottle of 'Zoom Spout' -Finest all purpose TURBINE OIL- and I dragged my poor bones back up on the roof and with the telescoping nozzle gave it a real good oiling from outside of it to every possible inside orifice...got Angel to finger turn it down below while I did this...and It worked! $$$$ Save Save Save!....Here's a picture of the bottle. Whats pretty neat about it- is that it has a telescoping plastic flexible tube that extens about ten inches.
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 08-11-2011, 09:36 PM   #19
1972 27' Overlander
Saline , Michigan
Any updates on your ac blower motor, is it still working or did you have to replace the motor.
loechli is offline   Reply With Quote
Vinyl on the inside dmaiden General Interior Topics 14 02-11-2007 07:43 PM
Inside AC vs exterior AC durans54 Furnaces, Heaters, Fireplaces & Air Conditioning 1 05-04-2006 05:40 PM
Inside Storage dmac Our Community 11 04-28-2006 02:08 PM
raining inside gotair Leaks - Weatherstrips, Gaskets, Caulks & Sealants 24 01-26-2005 07:11 PM
What does the inside look like? till Interior Restoration Forum 4 02-18-2004 08:19 PM
